Energy Generation by moving Mag Field through Static Steel Core & Copper Coils
Started by Ufopolitics, April 07, 2022, 09:40:19 AM
Ufopolitics
MAGNETIC VIEWING FILM, REVEALING MULTIPLE FIELDS WHILE ROTATION TAKING PLACE...
Here are a couple of pictures showing an "X-Ray View" from Magnetic Viewing Film, of coils during the rotation of the virtual field...
We observe a very slight, vague "rotation" around coils, which is based on the sequenced coils reversals...However, the center division lines for each coil still is there, not moving at all.
Resuming, this design, arrangement or geometry is NOT generating a True Singular Field...
I want to see a SINGULAR division wall for one singular field generated, and moving around as well as the field...this wall must be right at center of both field poles.
We need to be able to see this center line clearly moving along the right geometry, defining where our two poles are also moving...
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
bistander
Hi Ufo,
I know you and I disagree on how viewing film works and Bloch wall and you'll likely just make my post and opinion disappear, but  notice the similarities.
What appear as light fuzzy lines are caused by the flux coming from the end turns of the eight coils which you wound and not representative of the resultant field in the air gap.
bi
Ufopolitics
Quote from: bistander on May 11, 2022, 12:50:20 PM
Hi Ufo,
Hi  Bi,
Nope, You are wrong, I  will not make your post disappear... ;D
but  notice the similarities...
bi
Nope, you are wrong again...I just made a short video to demonstrate how it is shown that center line by viewing film...exactly at the center of the coil
Actually, Viewing Film works on Three Dimensional Magnetic Fields, no matter if Field is Permanent or Momentary...like a coil...it will always, very precisely, detect the center division line.
COILS CENTER LINE REVEALED BY MAGNETIC VIEWING FILM
I mean, and I know you could say whatever you want...but a simple demo will show it is not on the "end turns" of the coil.
Magnets do not have "end turns" however, the film also shows the same , exact, center line, on a Permanent Magnet.
And what that line is showing, is not "flux" either.
You could make this simple test as well, and see it for yourself.
Take care
Ufopolitics
―Leonardo da Vinci
bistander
Quote from: Ufopolitics on May 11, 2022, 02:24:15 PM
Hi  Bi,
Take care
Ufopolitics
Thanks Ufo for not deleting me.
You have said it is the "main field", and I can't see how that is different than, magnetic field, resultant field, flux field, air gap field, or whatever term you call it, that is the issue, or object of this exercise. And that is referred to as the B vector field. As such, North and South poles, and some imaginary demarcation between the two, are irrelevant, in fact non-existent. Would you agree that a "main field", magnetic flux field, exists in the core shown below? Where is this "Bloch" wall?
edit. Image from: http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/toroid.html
bi
Ufopolitics
Quote from: bistander on May 11, 2022, 03:19:40 PM
You have said it is the "main field", and I can't see how's that is different than, magnetic field, resultant field, flux field, air gap field, or whatever term you call it, that is the issue, or object of this exercise. And that is referred to as the B vector field. As such, North and South poles, and some imaginary demarcation between the two, are irrelevant, in fact non-existent. Would you agree that a "main field", magnetic flux field, exists in the core shown below? Where is this "Bloch" wall?
bi
Bistander,
No matter how much you twist or bend a coil...in any given shape, where you start winding to where you finish, in simple winding (no layers, no back and forth) like your image of the toroid shows, where current enters and where it leaves, right at the center from those two points (using the circumference-arc formula, since it is a circular geo) is where the center line would be...
Edit: Oh! and actually it  is not just a line, but a plane that goes across like a section of the given geometry...
Whenever I finish the winding of my Toroid, You and everyone would be able to see it...
It is irrelevant to start arguing about what or who this center line is...point is that it always exists in any given magnetic field, and the importance is that I will be using it as a reference to show rotation or displacement of the Field.
Therefore, I do not want to expand this debate at this point in time...so, please, let's leave it here.
Thanks for understanding
Ufopolitics
―Leonardo da Vinci
