Energy Generation by moving Mag Field through Static Steel Core & Copper Coils
Started by Ufopolitics, April 07, 2022, 09:40:19 AM
Ufopolitics
Hello to All,
I am in the process to wind a Toroid with 16 coils in series, 22.5º apart, to be driven by the same Rotary Switch...is a long process...
The Magnetic Field(s) would be rotating inside the Toroidal Steel Geometry...However, this particular setup will have Four Poles, or Two Magnetic Fields.
See image attached.
It is a simple way to wind it, one coil after the other one, all in series...but driven by each split joint to the switch.
Why did I changed -all the sudden- from one structure of a ¨Two Part¨ Generator with a "Stationary Rotor" to this type?
Because I want to be able to see the WHOLE Magnetic Field actually displacing...and I was not observing that...but the coils just "flashing" a rotation, while the Center line was "in situs"...Not good!!
And, so, I believe this fact, would not allow me to drive Field at higher speeds, without loosing it...loosing Inductance gain...
So...here I go...maybe a future TPU?...I don't know...tests will tell.
Here is a Short Video...showing Coil#1 and demonstrating where poles are, as well as the Center Line...
TOROID WINDING COIL#1
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Hello again...
I want to clarify that this "idea" to wind a Toroid did not just come "from thin air"...or as a guess...to shoot at different options, randomly...
There is a pretty large history about this idea, behind scenes...and now, since I already know how to do it right...(at least, I hope so) then I am going to make it happen!!
A Toroid is a very clever Geometry (related to Magnetic Fields), as this one I am working on is made of laminated steel...as any other Toroid Transformer is...
I actually have Three of these that I had ordered them a long while back...two smaller like the one shown on Video...plus another one much bigger.
Here is a Post that I wrote on another Thread, answering to a statement that Member Onepower made...but I want it here, to show all, where I am coming from...:
Quote from: onepower on May 08, 2022, 07:41:25 PM
It's also important to note that to my knowledge no credible FE device ever used lap windings as is found in almost all motor/generators today.
Quote from: Ufopolitics on May 09, 2022, 08:43:42 AM
Yes, you are very right AC...
The overlapping or lap winding is used to "save room", or to fit more wires per square area (referring to motors) and for generator coils it is overlapped to reach a higher number of conductors to be induced by the rotary sweeping inductor area.
Actually, did you ALL know that the only wires that are Induced on any Two Part Rotary Generator, even the stationary rotor type, we are working on...
that only the Vertical wires are Induced?!
Yes, and I am referring to the Vertical wires in ALL Coils on the Stator, the ones parallel to the shaft, whether a real shaft or an imaginary one?
All the Horizontal, or diametrical wires in the coils are just there serving as "connectors"...but no induction is generated?
This fact sets all these machines, automatically, at 50% Induction Efficiency!!
Now, it is impossible to build a machine (from the mechanical Engineering point) where the Induction coils or Exciter circuit, travels within a "fully closed tunnel" where all the Induced coils are wound...a completely closed tunnel...where the Stator Output Coils would be on the outside...
How can you rotate "physically" an inner set of coils and their steel cores, that could travel within another hollow, but fully closed structure?
However, that would be the "perfect generator", a 100% efficient from the Induction percentage area calculation point of view...
The only way that this type of generator could be conceived, is by rotating a Virtual Magnetic Field, not physically, not including its coils and cores...
And the only "Geometry" which can give Us such characteristics is a Toroid...
And then, we would not need to do "lap windings", or overlap the coils, none of them...just to be continuously set, one after the other...in a full closed circular arrangement...
Can You guys "imagine" that?
And then, set it to work in your minds?
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Quote from: Ufopolitics on May 11, 2022, 10:49:06 AM
MAGNETIC VIEWING FILM, REVEALING MULTIPLE FIELDS WHILE ROTATION TAKING PLACE...
Here are a couple of pictures showing an "X-Ray View" from Magnetic Viewing Film, of coils during the rotation of the virtual field...
We observe a very slight, vague "rotation" around coils, which is based on the sequenced coils reversals...However, the center division lines for each coil still is there, not moving at all.
Resuming, this design, arrangement or geometry is NOT generating a True Singular Field...
I want to see a SINGULAR division wall for one singular field generated, and moving around as well as the field...this wall must be right at center of both field poles.
We need to be able to see this center line clearly moving along the right geometry, defining where our two poles are also moving...
Ufopolitics
Hello,
I have just quoted myself on that post where I was not "happy" because not seen the center line displacement...
I WAS COMPLETELY WRONG!!
I did not realize that Magnetic Viewing Film is just like a Polaroid Film, which captures an image and it stays there, even if image stops showing...
The only way to clear, reset magnetic viewing film imaging, is by running a small magnet around it in a circular motion, and fairly some distance away from film.
And so, if we do not clear film it will remain showing whatever it captures...
Maybe in a future, they will make such "reactive film" to capture a dynamic field movement...
So, yes, I was wrong, and the Field does move, as its brighter center line as well...
If we have that :wall: code for the emoticon hitting a brick wall...I will load it here many times... ;D
Stay tuned, I just finished making a video...
Cheers
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Hello,
I am very  pleased to show this successful video about testing my future exciting field stator coils... ;D
EXCITING STATOR FIELDS TEST 1
Again this video is "Unlisted" not to show on my Channel, but only to those who have link...
I will comment on its results later on tomorrow...but I may be adding some more text here later, basically about things, details I did not shared at video...
Thanks for watching it,
Cheers
―Leonardo da Vinci
Ufopolitics
Hello,
A 60 second short video, shows that when I load a 90 Watts Incandescent bulb, Input Amps drops down...from 1.88 Amp to 1.56 Amps.
Video: Input Amps drop when loaded
Cheers
Ufopolitics
―Leonardo da Vinci
