helmut
Quote from: corona on February 18, 2007, 05:51:00 PM
I'm currently in the process of making a new coil, so once that's done I'll be able to take some scope shots.
Andrew
Hi Andrew
i just got the idea to use on each coil a adjustable coilresistor in series.
By this way you culd simulate different lenght of wire,to play with the resistens of the circuit.
Helmut
AhuraMazda
Quote from: fesearcher on February 18, 2007, 02:28:17 PM
The enclosed picture showes the motor.
There are two alterations I will do next.
First to improve the bearing of the rotor, which is only a porous bearing at the moment, in order to decrease friction loss.
Second, I will use another coil. This one is made is true trifilar winding. One wire is 0,25mm and the other two have 0,56mm in diameter. About 350 turns. I will change it to all 0,25mm to increase the numbers of turn.
@fesearcher
You've made an impressive device but from my arm chair it appears there is a large gap between the magnet and the coil. You should try to keep this distance to a minimum.
For bearings I would suggest ceramic bearings but these can be very expensive.
AM
AhuraMazda
IronHead
The best
Boca Bearing for the ceramic bearings.
They make little RC race car ceramic bearings as well.
Would be good for this project.
