Barbat low inertial mass generator
Started by tak22, April 21, 2007, 06:17:33 PM
Rosphere
I ran the blackening test again.  I took photos this time.
This time I rinsed the blackened wire end in a clean, (without salt,) H2O2 bath before it had time to dry to a green color like the first trial.  I was hoping that the extra oxygen present, as compared to plain water, would convert that green film into black without the need for the heating process.
I also suspect that it may be the sodium or the chloride in the salt that is reacting with the air and turning the film green, as in the first trial.  So, not only was I hoping to drive any CuO variants to pure CuO, but I was also aiming to rinse the sodium and chloride out of the film.  I did see very fine bubbles coming off the film in the rinse process.
The result appears to be the right color, black.  (Sorry about the low-res photos; the film coverage appears to be thick and complete.) I think that it may be the CuO film that we are after.
Any chemistry majors out there care to post the reaction equations for this process?
tak22
@rosphere and karl,
I can't really say how to create the 'correct' CuO film on wire and what it would look like, but I'm going to have to find one before I can start testing.
Once I get the wire oxidized I'll take a full length, cut it in half and clean/polish one piece for the control test, and use the oxidized piece for the Barbat effect .....
@Hans,
thanks for the PC scope links and info. I'll look into it, but I'll probably spring for something like this instead:
http://www.saelig.com/miva/merchant.mvc?Screen=PROD&Product_Code=PSSA002&Category_Code=PSSA
It's the time of year to be thinking of toys :D
tak
Rosphere
Rosphere
I found a product at my local hobby store called, "BLACKEN-IT," made by, "A-West."  It is used by model railroad enthusiasts to blacken metal parts made of brass, steel, nkl/slvr, copper, zamac.  (Not for aluminum or stainless steel.)  Contains denatured alcohol, selenous acid & dilute copper chloride/copper carbonate.  Cost was US$ 8.00 for 4 fluid ounces.
I used this product to blacken a small 20 AWG coil and ran some tests using a multimeter.  At about 3kHz +/- 2kHz range I was able to see 5mV on the output coil using several volts on the input coil, (both made of 28 AWG wire.)  I put enough current on the input coil that it started to heat and soften the plastic straw and clear tape covering.
I removed the blackened magnification coil and I still saw 5mV on the output coil.
So, either this product does not make the CuO film that we are after here, my setup is wrong in some other way, or the concept has no merit.
Has anyone had any success with a Barbat replication?
pese
interering patent.
how , i can find to that was was the HUBBARD - Device ??
Scematics here:
http://pese.150m.com/hubb/index.html
Click on #21 !!
more
http://pese.150m.com/fe/
after this was working with wome watt?s
Hibbard have used "radium" to magnifie
the power to some hp. to drive
an boat , an car , also his
electricity at home.
Pese
