The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
EMdevices
My electrolitic capacitor is so awesome, it doesn't even need a coil to start going up in voltage   :)
EM
hartiberlin
Hey Wattsups,
great !
But please try with an analog voltmeter
without any battery in it.
Maybe there is some coupling from the analog to digital
converter of the DVM to your coils  ?
Or is there a Mobile phone broadcast tower near by ?
Please try to shield it all in alufoil or in an iron case and try it again.
Please don?t connect any scope ground to it,
cause I once had something simularandit was caused by my scope ground
coupling in some potential.
Many thanks and good luck !
Regards, Stefan.
z_p_e
Quote from: EMdevices on July 06, 2007, 09:53:35 PM
EM
So EM, wattsup,
Is this then charging via ambient noise picked up by the coils, or perhaps capacitor recovery, or a combination of both?
@wattsup, is your coil oscillating that you said resonance?
Darren
Doug56
@ All
I finished my device yesterday and already I started to make some tests. See the pictures below - photo 1.
Is a small device (the ruler is im cm), but I get some unexpected results. Fascinating!
I'm making tests without using capacitors therefore I'm without none in good conditions here.
I connected the output to my digital multimeter and input to my PC audio amplifier.
I recorded several waves in several frequencies (squared and senoidal) in Audacity software and play it in PC.
The mutimeter show oscilations between 0.2 to 0.5 volts DC and in AC scale is ever in 2.5 v while playng the waves.
Then I played a music and the display showed a voltage between 3v to 6v DC (remember, without capacitors or any other electronic peaces) - see picture 2.
It seems that the volume does not matter. What matters is the input signal frequency. This makes all difference!
Sorry for poor picture quality. I used my cell phone to take this photos.
Tomorrow I buy some capacitors and continue making tests.
I used domestic aluminium foils in my device, and each set has the follow layers: iron core / electrical tape / aluminium / crepe tape (as insulator) / secundary coil (thin cooper wire) 90 turns / crepe tape / aluminuim / crepe tape / primary coil (thick cooper wire isolated) 21 turns
Regards.
Doug
starcruiser
Doug,
Have you tried to meter the foil or the core?
Regards,
Carl
