The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
EMdevices
Quote from: jacob on July 02, 2007, 06:45:29 AM
Quote from: -[marco]- on July 01, 2007, 12:23:40 PM
The talk goes around the Farland Cook patents has been deliberatly changed.....
I do not know the reference source of where i heard it, but i am sure it was about these particulair coils.
Yes it was. And you heard it from me Marco. I made that claim a few times and the reason is simple. When you read the patent, it refers to elements in the drawing that are absent from the document. Therefore the conclusion that the drawing has been altered by simply erasing some of the circuit elements.
Jacob
Jacob,  if you would be so kind, can you provide a reference for your claim.
I scanned the patent over and I don't see any references to other figures besides Figure 1 and Figure 2.  (I used www.pat2pdf.org)  Perhaps you have a hard copy with a different text?    By the way, the No 16 and No 30 referenced in the document mean wire number, or size, or gage, not a part number on some missing figure, at least that's the way I read it.
EM
EMdevices
Bruce,   take it easy there, you're his only hope  !!!   :D  :)
Seriously, I belive the clamps you see are from the scope, we can see those in the other photos.
Why the meter is down CLOSE to zero is another story.
The yellow wires from down below are the only unsettling question for me,  but the wires maybe came with the plastic connector, and the batteri leads connect to the yellow wires down bellow.   I'll give him the benefit of doubt untill prove quilty  :)
EM
Bruce_TPU
EM,
Please look closely at the three prongs.   I have some serious concerns that there is NO INPUT to them BESIDES the two jumper cables.  That is the only input I see.
Cheers,
Bruce
Bruce_TPU
EMdevices
Bruce, why don't you anotate my zoomed in photo.  What do you mean?  Place some labels on it.
I would think if he wanted to trick us he would use the yellow wires, but you never know.  Let's hope he wasn't out to have a good laugh on us.   :D
EM
