The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
Bruce_TPU
@ Jacob and Wattsup
Very good, I will hold my peace.  I still do not see it in the pictures, but that's fine.  Just having started the thread, I feel responsible and feel it is imperitive to make sure the integrity of the information given to us is honest.  I will feel much better with a confirmed replication.
@EM
Yes, I see the meter on DC.  So I do feel better about that.
@brnbrade
Please make sure all photographs show all wires and radio please, to remove room for doubt.  Thank you!  ;)
Happy Days, Again!  LOL
Bruce  :)
EMdevices
Oh good, suny days once again.Ã,  :)Ã, Ã,
Now,Ã,  I was theorizing that maybe some sort of galvanic action might be happening, but I don't know anymore.Ã, Ã,  This thing has DC amplification?Ã, Ã,  Wow,Ã,  now it's even more puzzling.
I mean, if it would of been AC, it would of made more sense, but DC output?Ã,  How in the world is that getting generated?
Aluminum foil?Ã, Ã,  Well, I would say that it's a filter for the mag fields.Ã, Ã,  Only SLOW VARRING FLUX WILL PENETRATE, HIGH FREQUENCY WILL BE REPELLED.Ã,  And yes, it blocks E-fields as well, but we're dealing with DC now, not AC.
Very strange device!
So here is what I suggest.  Build two cylindrical capacitor and interconnect them as shown.  Since it's DC, the windings don't do much, or do they?
Just a thought for reducing complexity to find the answer.
EM
Bruce_TPU
Quote from: EMdevices on July 02, 2007, 12:31:27 PM
I mean, if it would of been AC, it would of made more sense, but DC output?  How in the world is that getting generated?
Aluminum foil?   Well, I would say that it's a filter for the mag fields.   Only SLOW VARRING FLUX WILL PENETRATE, HIGH FREQUENCY WILL BE REPELLED.  And yes, it blocks E-fields as well, but we're dealing with DC now, not AC.
Hi EM,
I am sorry, what did I miss??  Brnbrade was very clear that the output of his device was AC.  The input DC.
Thanks, :)
Happy Sunny Days!
Bruce
EMdevices
Oh you're right Bruce, he does say it's AC, 52 V, then AC 250 V or so.
But then what's with the scope picture showing the meter on DC?  Is this thing producing both AC and DC?   (look at the first two pictures he posted, one is AC the other DC, same configuration)
EM
EMdevices
Question:  How did you measure the amps?
Answer:  No mesure. I no amper reader.
This is strange, his meter can do Amp readings as well, does he not know how to use it?   As in "I no good at reading meter?"
Hmmm
EM
