Tubes?
Started by Super God, July 18, 2007, 06:46:18 PM
Bruce_TPU
Hello All,
The MRA2 sounds like an even better and much closer fit than the original MRA1.  Check this out:
MRA2:  Magnetic Resonance Antenna?
Further research by Norman Wootan, Joel McClain, Robert D. Taylor and Tim and simplified version.
28 Aug 1995
Tapping A New Ambient Power Source By Resonant Ecitation ~
It has been discovered that an apparently hitherto unknown or unexploited source of ambient power exists everywhere on  earth (extrapolating from experiments in Atlanta, GA and Austin,  TX!)  and from which essentially "FREE" energy can be  extracted at almost no cost, merely by using  the Key Concept in the Wootan/McClain discovery, namely external  armonic excitation of a saturable core transformer, which causes it to act like an Antenna that extracts ambient energy in amounts 19 times or more than the energy required for the harmonic excitation. Indeed, the original MRA design continues to work and to exceed all original expectations.
In the MRA2 configuration, even when the piezoelectric capacitor has been removed and even when the primary resonant circuit has been cut, it still continues to produce verifiable output power! All that is required is a single wire from the AC Signal  Generator to the saturable-core transformer of the original MRA disclosure in order to cause useful power to be generated in the secondary circuit in amounts vastly greater than the power input from the harmonic Signal Generator.
This appears to be an electrical analogue of the chemical phenomenon of Catalysis, namely the periodic pulses of energy into the transformer 'catalyze' the transformer's nature so that it operates in an apparently hitherto never before seen mode, namely it behaves like a novel 'Antenna' which is extracting AMBIENT ENERGY from "somewhere"! It is not necessary to understand completely at this time what the source of Ambient Energy may be, in order to exploit the phenomenon in an environmentally benign way for the benefit of mankind.
Numerous maverick scientists and engineers have suggested that there may be hitherto unknown aspects of electromagnetic radiation not comprehended in the standard Maxwell's Equations, such as the controversial "scalar  waves" postulated by  retired Air Force Colonel Tom Bearden.
Retired physicist Greg Hodowanec, who duplicated the MRA independently after learning about it from the New Energy News newsletter, which reproduced the internet announcement of Wootan and McClain, suggests that the ambient energy  comes from the earth's gravitational field and is somehow being converted into electrical energy.
Former BYU professor of Physics & Astronomy, Dr. Bob Bass speculates that MRA2 (as was the original MRA1) may be somehow tapping the ambient electromagnetic energy known to exist in the Earth-Ionosphere Cavity in the form of Schumann  Resonances which are continually resupplied every time a lightning bolt from a cloud strikes the earth. "As explained in the Second Edition of Jackson's classical book on Electromagnetism, the great genius Nikola Tesla discovered the Schumann resonances experimentally 50 years before Schumann predicted them theoretically," says Bass, who adds that he once calculated that "every cubic meter of space near the surface of the earth contains on the order of one kilowatt of standing waves, similar to those in a microwave oven except at vastly reduced frequencies, which no one knows how to extract efficiently." Or do they? The late Utah inventor Moray, author of a book entitled "The Sea of Energy in Which the Earth Floats", astounded famous scientists in the 1920s and 1930s with never-explained demonstrations of his ability to extract 3 kilowatts from 'nowhere' at will, anywhere (even randomly selected points in the desert), using his unexplained Moray Valve.   Moray submitted a Patent Application, but withdrew it and his secret died with him. Admirers of Moray point out that his  writings included the words "Germanium triode" decades before the Transistor was discovered by Bell Labs scientists (who won a Nobel Prize) and who had been directed into solid-state physics by the late Harvey Fletcher, who had earlier witnessed Moray's work and been shown every detail except the secret of the vest-pocket-sized Moray Valve.
A recent controversial theory of Austin Institute for Advanced Study physicist Hal Puthoff and his collaborators Haisch and Rueda appears to explain gravity as not an intrinsic property of matter but as an indirect consequence of Maxwellian electromagnetic radiation, namely that (as earlier suggested by the late Russian dissenter Sakharov) gravity is a "shadow  effect" similar to the accepted Casimir Effect of quantum electrodynamics. Bass points out that if the Haisch-Puthoff-Rueda theory is correct then Hodowanec's idea of tapping the earth's gravity field in some electromagnetic way not hitherto suggested is conceivable.
Whatever the Ambient Energy Reservoir into which the MRA is tapping, the novel phenomenon is real and deserving of exhaustive further investigation, according to elated inventors Wootan, McClain, Taylor and McCracken, who urge independent investigators to seek to replicate their discovery.
Below is a circuit for the MRA1.  As yet I have been unable to find a schematic for the MRA2.
Bruce
otto
Hello all
now we are talking!!
Thanks Bruce.
Otto
turbo
Quote from: otto on August 24, 2007, 07:34:06 AM
Hello all
Thanks Bruce.
Otto
Sure Otto now we are talking eh.
so, what happend to your ECD??
Did it float away because of the weight loss?
@Bruce , i was just about going to cover the Mra2 in the same fashion i did with the previous one, but you did the dirty copy paste thing so it wont be nessisairy, i guess.
the readers can figure it out by their selves.
i'm out, i got some other things to take care of lately.
Have fun all.
Marco.
otto
Hello all,
@Marco
Im fine, my ECD - TPU is fine....its still on my workbench.....thanks for asking.
Otto
z_p_e
Quote from: Grumpy on August 24, 2007, 12:02:33 AM
Like a damn "soap opera" in here.
SM used tubes to determine the frequencies - detectors.  Something about SS being too slow to see them.  Once this task was done - no tubes.
Very sharp pulses will create harmonics in the microwave region.
If one digs a little deeper, they will also find that HF and RF "noise" outside the device can reach high levels..high enough to disrupt the operation of SS devices. Hence the need to keep them in the ring.
Tubes are not susceptible to this type of interference (why does the Russian military still use tube equipment?) and therefore allow for better and sustained control of the frequencies being applied to make catalyst.
Obviously the speed of SS is not the real issue here, but their stability in noisy environments is. Incidentally, IR has a line of MOSFETs that are "radiation hardened", and are meant primarily for space applications. Perhaps there are other IC's out there that also fall under this category.
@Grumpy,
Welcome to the "soap opera". Any constructive contributions are most welcome.
Cheers,
Darren
