0 Members and 38 Guests are viewing this topic.
markdansie
Hi Lawence,
i would test output using a pony brake in the first instance.
We can hook up a permanant magnet generator as well that has low cogging but would need to step up the RPM . I know an excellent generator out of the USA used for wind mills.
You can possibly borrow a good wind mill generator (say 500watt) in china
This would also enable it to be closed looped back to battery so we can load up the device with a resistance load (even lamps would do) to see if it can maintain it self running.
RPM is easy..you use a cheap laser device (hand held)
Mark
markdansie
Just one question,
did you notice the amps increase when you tried braking it with your hand. You mentioned it was drawing 2.4 amps at 12 volts (proberbly 14 volts) is this correct
Mark
Top Gun
Quote from: markdansie on July 30, 2009, 07:07:27 PM
Hi Lawence,
Mark
Dear Mark,
Thank you for your quick response.  We plan to get similar test equipment in Hong Kong or China first.  If we fail to get any particular item, we may need your help to get it from USA.
Our next presentation will be at the Hong Kong Institute of Energy on August 5.  However, we can make special arrangement for you to examine the prototype.  I still believe that you should wair for our next 16 coil prototype.
Regards,
Lawrence
ltseung888
Here is the second presentation slide explaining the Lee-Tseung Lead-Out Energy
Can we continuously lead-out gravitational energy?
The Bessler Wheel in the 1700s in Germany may be one such device.
ltseung888
Quote from: markdansie on July 30, 2009, 07:15:36 PM
Just one question,
Mark
I played with the earlier protoype in my living room.  The Amps as shown on the meter rapidly decreased when I braked to reduce the rotational speed.  When I let my hand go, the rotational speed and Amp increased again.
Does that answer your question?
