ltseung888
The third slide is the key one.  It was probably the first time that theoreticians actually calculated the quantity of Lead-Out Energy from a pulled pendulum.
The result was a great surprise and a great delight to Lee and Tseung.  Two parts of horizontal energy supplied could lead-out One part of vertical gravitational energy.  This represented a potential COP of 1.5.  Such a large figure could be verified experimentally.
Whenever the COP is greater than 1, there is possibility of loop-back so that some of the Output Energy could be fed back to the Input.  Once that occurs, no more Input Energy is needed.  The resulting COP figure will be much higher.  This explains that the Tong Po Chi Prototype can have COP more than 10.
With the above calculations, Lee and Tseung became so confident that no amount of negative feedback could shake their confidence.
Devil
Tseung, your prototype still has room for 3 more coils.
You can still train the students to produce these extra coils, insert them into the prototype and improve the electronics to cater for these extra coils.  Rather than sitting on the sideline and watch, they can still contribute.
You gave them too much responsibility at the beginning â€" hoping some 18 year olds with no working experience will produce prototypes that shake the World.  The new task is more manageable.  They may succeed.
When they gain confidence, ask them to build the larger prototype to cater for 16 coils.  Their solution based on the HK$10 proximity switch cannot be actual products to produce electricity.  However the device will be more than enough to prove overunity.  You can publish and share their work with the World.  They can even win the Overunity.com prize.
You want to Help Seedlings Innovate.  Mr. Tong Po Chi is not a seedling.  He is already a tall tree that can provide shelter and fruits.  Think about it.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
ltseung888
 Slide 4 extends the Lead-Out Theory to magnetic fields.  It also extends the theory to beyond oscillation systems.  This means the much more efficient rotational or flux change systems can be used.
ltseung888
We were worrying about the proximity switch not sensitive enough to provide us with a high enough frequency.
We were looking into more advanced laser type technology.
Is is possible to use the simple collector coil function?  A Collector Coil produces current when a magnet passes by.  Can we use this property instead of the proximilty switch?  What are the additional electronics we need to add?
Suggestions are welcome.
Pirate88179
@ Lawrence:
That is exactly how my Bedini motors work.  It is wound bifilar but it is used as 2 different coils on the same spool around the core.  One is the power coil and the other is the trigger coil and, if you have seen any of my videos, it works at very, very high rpms.
For a good explanation and good circuit diagrams, look up Introvertebrate on youtube as he has 3 videos that explain it all very well.
Well, here is the link for the first one: http://www.youtube.com/watch?v=zJySgeSpJpQ&feature=related
You can find the other 2 by looking up his other videos listed on the right of the viewing screen.  Hope this helps.
