The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
teslaalset
Quote from: Paul-R on November 25, 2009, 10:39:11 AM
But if a charged coil discharges, there will be BEMF to be had. It
shouldn't be wasted.
***Waste not, want not. ***
Paul, that has been advised to Lawrence earlier (page 473 reply #4724) to add that feature to increase his COP. He said he understood but has not implemented this yet.
ltseung888
More experimental results from IVE
In the first row of the spreadsheet, we showed the result of 6 connector coils in series with no external load.  The DC voltage was 32 volts.  That should be enough to recharge the 12V batteries.  The Output current was 0 Amp which should be the correct value.
However, in the second row, with a 3 watt light bulb as load, the voltage dropped to 8V.  That would not be enough to recharge a 12V battery.  However, that could easily recharge a 6V battery.  That explained why we could not recharge the rundown 12V battery but could recharge the rundown 6V battery.
One lesson learned from this is that the internal construction (especially resistance) of the wheel is important to the final results.  We need to reduce resistance to a minimum via soldering rather than clipping.  We need to reduce wire length to a minimum and use thicker wires.
There is a small concern related to the last few rows related to increasing Input voltage.  The Output power increased but COP decreased to less than 1.  This showed increasing voltage had similar effect as increasing number of Drive Coils â€" when a certain threshold is reached, more does not help.
Meanwhile we have to check whether we can still win the Overunity Prize if we need to swap the batteries from time to time.
We know that we are wasting the AC voltage component of the INPUT â€" the Drive Coils acting as Collector Coils at no Pulse.  We may use additional circuitry to capture such energy.  Science is never boring.
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
Pirate88179
Lawrence:
You had better hurry, Gadgetmall has applied for the Overunity Prize with his Joule Thief B-cap circuit.
Bill
chrisC
Quote from: ltseung888 on November 25, 2009, 08:56:30 PM
Lawrence Tseung
Director
Swapping batteries to win the Overunity prize? Haha! You're a real comedian Mr. Tseung.
Bad science is ALWAYS boring!
cheers
chrisC
Cap-Z-ro
Or maybe Santa has a low sperm count from always carrying his bag over his shoulder ?
Regards...
