Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
4Tesla
Yep, maybe the MTPU can be used someway to boost the power for the Earth ground battery... good idea!  :)
4Tesla
4Tesla
Quote from: btentzer on November 29, 2007, 04:02:36 PM
Quote from: Localjoe on November 29, 2007, 12:30:11 PM
Good odd ball refrence i found that design looks similar to stiffler's circuit just because of the coil ends... figured it might be helpful conceptually
        Joe                      http://leedskalnin.com/Magneticinductionclip.html
@ All
Did you notice the  Iron wire he used on his coil?   ;D  That is soon, going to be a test for me with this circuit, I promise!  Iron wire wrapped toroid.
Holiday Cheers,
Bruce
When you get the iron wire are you going to have one iron coil and one copper coil or both of the coils going to be iron... or are you going to try both ways?  The other thing is which coil would be iron the primary or the secondary.. another thing that can be tested both ways.
4Tesla
Bruce_TPU
Quote from: 4Tesla on November 29, 2007, 07:45:44 PM
4Tesla
@ 4Tesla
Yes to your first and second question.  I will keep my 20 gauge copper coil I am using now, and rewind another toroid ferrite core.  I have three of them.  I will then test the iron wire with this set up, and then test both of them together, and about 4 or 5 other experiments teasing my brain.   ;D
@All
I have just arrived home and I am about to go outside and test earth ground in two or three configurations.  We will see what happens.  I will let you know.
Holiday Cheers,
Bruce
EDIT:
I ran three separate experiments tonight, two being hooked to earth ground.  Three minutes and five minutes LESS run time.  So that is a no go.
Tomorrow I look for iron wire locally and rewind my barium ferrite coil core secondary.  I will also seriously research transistors.
acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
Grumpy
        -Frank Edwards
