Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Silvije
@All, could you measure current which goes through LED?
Also it would be helpfull if you provide voltage drop for you LEDs,
and minimum current for lets say enough bright operation...
so we could compare these super bright LEDs performance...
I am using yellow 4-legs superflux led from lumileds i think..
thnx.
ps. how come noone commented this link http://www.allweathercandles.com/product_zoom.php?tipsvece=G300
eon
hi all
been very busy with work commitments, but been doing a few experiments.  i started looking at winding a moebius coil and found this (further down on the page) on a toroidal.  i know a little about moebius coils but it doesn't look like 'the typical moebius' setup.
http://jnaudin.free.fr/html/tripole.htm
i have free time this week and will be producing two identical halves as a little test.  anyone else tried this yet?
i have taken apart my original 'cap in coil' setup but i can say that with different loads and a higher starting volts, it did some strange things like the very bright blips at the end (slower).  it sometimes didn't start for 10-15sec after charging but then started suddenly after a very bright flash.  i notice that sometimes the led just starts flashing and other times it just lights until i remove the battery then off it goes.
i cant find insulated iron wire for love nor money round here, so i may just get some bare and coat it. does it have to be insulated?
Silvije
i have modified original schematic and added second LED, to the collector circuit
this one blinks much brighter than one in recapture circuit, so it seems much higher
current pulses live there
this explains my 4 dead transistors so far
Bruce_TPU
Quote from: eon on December 02, 2007, 07:41:30 AM
hi all
@ Eon
To answer your question, yes it needs to be insulated.  I tried it without, and it does not work.  I too have seen all the things you described, but with modifications, it simply blinks from the second it is kick  started, until it becomes so dim it fades out in the final seconds.
Quote from: Silvije on December 02, 2007, 07:43:07 AM
@ Silvije
Good work.  Please be kind enough to post your modified circuit,  it may help me with an idea I have not yet thought of.
I am using a standard 3.7 volt, 20 ma LED from Radio Shack.  All colors work, though BLUE seems to be the absolute brightest.  I think it has more phosphorus in it, thus more mcd rating.
@ ALL
I have increased my run time consistently by 10 seconds.  (baby steps) I have added a 1N4007 diode (I tried it with a germanium, but not the same run time) on the negative side of the 1.5uf capacitor, with voltage going to this cap.  Today I will try it in reverse and a few other experiments I can think of.
New Best Run Time:  39 minutes 7 seconds
Goal:  To continue to increase the run time, as much as possible, until I have run completely out of ideas.  (I have a lot of them) Then I want to use this oscillator to kick start EM's Dr. Shifflers modified circuit (yes, I know it will only flash) and then feed that back to the oscillator and self sustain.  Big goals, I know!   ;D
Holiday Cheers,
Bruce
scorpio
Hi,
@mramos
Here is a pictures and schematic from my micro TPU. It really rans 10 hours and 52 minutes!
You need charge the supercap (0.22F) till 30 seconds. Charge voltage is 5.5V.
scorpio
