Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
otto
Hello all,
@wattsup
I only showed - posted this drawing nothing else. Its not mine.
Otto
4Tesla
4Tesla
Has anyone bought anything from the site below?  I still haven't gotten my toroids.. starting to get frustrated with this company.  I sent them an e-mail and no reply.. I guess I try calling them next.   >:( >:(
4Tesla
Edit: I checked their contact info and they are in RI and I am in WA.. ground shipping and I-5 closed for a few days from flooding.. I'll give them a few more days, probably Tuesday, before I call.
Quote from: 4Tesla on November 26, 2007, 07:45:46 PM
I bought 2 of the FT114-77 1.14" ferrite toroids, 1 of the FT140-77 1.4" ferrite toroids, and 1 of the T106-26 1.06" iron toroids.
Site: http://www.oselectronics.com/ose_p88.htm
Bruce_TPU
Hello All,
I am still here!   ;)  I have run experiments every night, but to no avail.  Still stuck at 39 minutes.
Tonight I over wrapped each half of the toroid with a second set of control wires, and hooked them up mobius, but using diodes to make the racetrack.  Idea is a spin off of Mannix's graphic and thoughts.
Induction kick starts the racetrack and around it goes, inducing more current into the wrapping under it, and thus it continues...(in my head anyway!  LOL   ;D)  If it doesn't work, it should!  LOL
I will let you know if anything comes of it.  It took a while to set up.
Holiday Cheers,
Bruce
EDIT:
Okay, I have a brain tease for some bright person out there...
My second set of control wires, wrapped over the other wires, and connected with mobius and diodes.  If I connect one diode opposite direction (Where it kills the race track) the LED will not light at all!  Now remember, none of these wires are connected to the circuit at all in this experiment.  Why is that?  What is your answer??   ???
CTG Labs
Hi Bruce,
Is there a diagram?  Perhaps the diode in this direction is allowing the isolated coil to act as a "shorted loop" and absorbs all the energy?  If the diode is reversed it does not conduct, because perhaps the signal is pulsed DC not AC and has only one direction?!
D.
