The Tesla Project
Started by allcanadian, January 22, 2008, 05:56:53 PM
0 Members and 23 Guests are viewing this topic.
amigo
Charlie_V
In the video link I posted, start watching from 40' mark, if you do not have time to see the whole thing (though I suggest watching from the beginning).
I believe that the real "meat and potatoes" we need to understand start at 40', and up to 50' of that video, in relation to Tesla and things in general pertaining to our research.
Groundloop
@Wattsup,
Regrading the circuit problem we discussed. I think I have a solution for your circuit.
The attached circuit uses two 3 ampere reed relays to switch the transformer to
and from the input. The relay coil must be as high DC ohm as possible so that the
coil will switch the reed relays but not use much extra power from the input.
I hope that this was what your where looking for.
Groundloop.
armagdn03
Hello everybody
I am really impressed seeing the work of Gotoluc, and the ideas people are coming up with. I personally think its important to know what you are dealing with before you start using the concepts in design, and that’s what seems to be happening.
Groundloop and Wattsup
the circuit that was posted above is a clever one, and has been tried (with respect to the oscillator triggering the circuit controller) and I think its possible to pull off, but mechanically it’s a  bit hard. The reason being that the response of the reed switch is somewhat slow. Meaning what you need is the controller to pulse at the perfect time to re-enforce the previous train of waves, but the switch in this case will always be off by a bit. And since it is triggering itself it can be a self defeating cycle, unless play with the phase a bit for adjustment. Definitely on the right track and that circuit is doable.
The importance isn’t necessarily in the components used, or  the exact configuration, it’s the circuit triggering itself.
Keep up the good stuff.
I wish I could turn my brain off sometimes, then I could get some sleep.
ramset
Armagdn03
Thank you for your input
Can you suggest a faster [more appropriate] trigger system
  Chet
Thanks Grandma
armagdn03
you can use what you have, just adjust the phase of the pulse, many ways to acomplish this. Or you can go solid state, hall effect sensors, trigger coils, etc. Even with these, you may need to adjust phase. Just think the problem through logically, what is your end goal, and will your setup create the conditions to get that? If you are just throwing things together to see what will happen, you obviously cannot do this, but you may still learn alot! In that case ask, what happened, and how did my setup create the conditions for that to happen?
Sorry if thats a bit of a duh awnser. But I have definitly spent nights wondering what the hell was happening, and reverse engineering the logic behind what I saw.
