My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
capacitor70
Quote from: xbox hacker on July 21, 2008, 11:20:43 AM
we need a high frequency cap charger...
Here is a PDF i found...we might be able to use this for something..
http://forum.4hv.org/attachments/Capacitor20Charger20Circuit.pdf
You are not reading my all posts, It is already there in forum and working with less number of components...
Super God
Wow, so you REALLY need this system then =D  This is great news for you and your community, now that finally have something that works.  I'm glad we could all work together to make this work.
>9000
xbox hacker
Quote from: capacitor70 on July 21, 2008, 11:31:26 AM
I might have missed it...send me a link...
vrand
Quote from: capacitor70 on July 21, 2008, 11:11:56 AM
Today I assembled engine again with new piston rings and oil seals, Tomorrow taking trials again with new coil based plasma generation circuit......
Its not truck strike, demand is more and supply is less , car line is there but on the road sides ,Petrol is too much expensive here in India and we have to wait 2 or more hours at petrol pumps to get it....food prices are going high...No raining....
Hi,
Good to hear that your test engine is back again for testing.  Looking forward to your new design research results.
Possible test for "Charging water"
Water is different worldwide in the natural concentrations of the electric charge of the calcium and magnesium ions present in nearly all sources of drinking water.
From: peterfallenbach over at WaterFuel1978@yahoogroups.com:
...You can "charge" the water prior to letting it into the cylinder, or you can do it right before the firing.
If the water will see just one side of the HV prior to the firing it will become ionized. Surely not as strong as if one could outside, but better than nothing.
This would also mean, that it could be a good improvement to fire the HV again and again during the combustion, so that more and more electrons get sucked away from the plasma, and so the explosion would
be even stronger.
There would also be other ways. E.g. like Stan did it by making a circuit which blocks the introduction of the electrons in the water a bit and therefore it starts to get this charge imbalance.
Michael Randall
Gearhead
If you want charged water find someone with a water ionizer.  These things plug into the wall and can easily change the pH down tp 2.5 or up to 9.5 just by the charge.  You can find an ionizer like enagic or jupiter on ebay.
