Thane Heins Perepiteia.
LarryC
Quote from: Gustav22 on October 18, 2008, 01:20:10 AM
You can find and download the patent here (unfortunately only in German language):
http://v3.espacenet.com/origdoc?DB=EPODOC&IDX=DE202008009291U&F=0&QPN=DE202008009291U
Yes, it is very interesting, if this works as stated it is a major game changer.
Can anyone help with the german translation. Would like to test and wondering if the capacitors are the same as AC motor type.
Thanks, Larry
i_ron
Quote from: LarryC on October 18, 2008, 07:26:52 PM
Thanks, Larry
They give the volts amps coil size and cap value on page 3 and 4 in 'descriptions'
50mfd for example and 50 Hz is mentioned so I would guess oil filled motor 'run' caps would be OK.
Keep us posted
Ron
AbbaRue
@Gustav22
I wonder if that German circuit would work using a regular transformer instead of winding a special coil.
Gustav22
Quote from: AbbaRue on October 18, 2008, 11:25:23 PM
@Gustav22
According to my understanding of the patent, a normal transformer can not be used (unless it was re-wound), as the winding style described in the patent requires two parallel wound wires (much like a 'bifilar' coil), so that the parallel 'strands' act like the two plates of a capacitor.
This points to the fact that finally all neighboring strands form a multi layered capacitor - with an additional capacitor at each end and these two 'terminal caps' presumably are put in place to regulate/adjust/calibrate the capacitance of the whole.
Normal transformers are not wound like that - as usually the complete primary and secondary are wound independently and on top of each other - and so presumably a normal transformer will not work as required to achieve the effect described in the patent.
money for rope
CRANKYpants
Quote from: Gustav22 on October 19, 2008, 04:55:39 AM
...SO THE "CAPACITORS" CHARGE AT RESONANCE WHEN THE INDUCTIVE REACTANCE AND CAPACITIVE REACTANCE CANCEL EACH OTHER OUT... AND THEN DICHARGE THROUGH THE COIL'S DC RESISTANCE TO PRODUCE A MAGNETIC FIELD ???
LARRY - WHAT ABOUT MAKING A PRIMARY LIKE THIS AND INCLUDING IT IN MY BI-TOROID TRANSFORMER DESIGN?
Thane
