Thane Heins Perepiteia.
0 Members and 16 Guests are viewing this topic.
Quote from: hop toad on February 25, 2009, 06:17:24 PM
OU  ...... ???  without any reference to input power to the motor driving the system  ??
To be OU, your 21 watts electrical output and shaft torque (mechanical output) combined must be greater than the input power consumed by the driving motor.
Without input power data versus output power (including shaft torque measurements) data, your claim of "WE ARE OPERATING AT OVERUNITY" is extremely tenuous.
Cheers
Both if you may have valid arguments. It depends on how efficiently the motor conserves the electric energy to mechanical at 25rpm.
CRANKYpants
Quote from: hoptoad on February 25, 2009, 06:17:24 PM
Cheers
OK, THE MOTOR AND GENERATOR ARE BOTH 100% EFFICIENT AND ALL THE ELECTRICAL POWER IS CONVERTED INTO MECHANICAL POWER IN THE DRIVE SHAFT AND THEN ELECTRICAL POWER IN THE GENERATOR (WE USE MAGNETIC BEARINGS IN A VACUUM).
WITHOUT THE HV COILS ENGAGED THE MOTOR CONSUMES 0.003 WATTS TO PRODUCE 0.003 WATTS, EFFICIENCY = 100%
WITH THE HV COILS ENGAGED THE SYSTEM ACCELERATES AND THE FIXED MOTOR INPUT = 0.003 WATTS (ACTUALLY IT IS GENERALLY ABOUT 50% LESS WITH HV ACCELERATION BUT FORGET THAT PART) AND THE GENERATOR OUTPUT = 21 WATTS.
21/0.003 x 100 = EFFICIENCY 700,000%
CHEERS
T
Quote from: CRANKYpants on February 25, 2009, 07:37:37 PM
CHEERS
T
1 million % would have been rounder. I think you'd pass that if you did divide by 2 AND considered the kinetic energy of the rotor.
CRANKYpants
Quote from: aTg on February 25, 2009, 10:30:31 AM
hi,
This is my new test with 0.2mm coil wire
http://www.youtube.com/watch?v=1JC0UwnZrcU
Lenz's law working. :(
VERY NICE VIDEO!  8)
LENZ NAMED HIS LAW AFTER HIS WIFE - WHO WAS A PERSISTENT BITCH!  :-\
MAY I SUGGEST 100 OHMS OF 30 GAUGE WIRE ON AN AC MIG WELDING ROD?
CHEERS
Thane
CRANKYpants
Quote from: broli on February 25, 2009, 07:41:53 PM
WELL OF COURSE I WANTED TO BE CONSERVATIVE AND NOT RUFFLE ANY FEATHERS...  :-[
Quotekinetic energy of the rotor
NO KIDDING A 10 LB ROTOR ACCELERATING UP TO 3500 RPM FROM 25 RPM WITHOUT ANY ADDITIONAL POWER TO THE MOTOR - WHILE DELIVERING POWER TO A LOAD AT THE SAME TIME - BOTH - GOING UP AND COMING DOWN.
T
