Thane Heins Perepiteia.
JustMe
Quote from: LarryC on March 21, 2008, 01:06:39 PM
@All,
The weirdest thing about PB is he never gets upset when informed of his ignorance or lack of common sense. Anyone who actually believes that they are contributing something useful to this forum would have went ballistic by now.
He sends snipey little passive agressive PMs instead, ostensibly so he can keep the public discussion full of thinly disguised contempt objective.
OilBarren
Quote from: bitbeam on March 21, 2008, 12:22:06 PM
Hi Thane,
It sounds like your NASA trip is still on, is that correct?
I hope so!  :)
Aaron
YES IT IS STILL ON - WHY DO YOU WANT TO COME ALONG?
ACTUALLY IT MIGHT BE OFF IF PB WORKS THERE - HE'LL NEVER LET ME IN.
LET ME GET BACK TO YOU ON THAT.
POLAR - DO YOU WORK FOR NASA BY ANY CHANCE?
Thane
OilBarren
Quote from: polarbreeze on March 21, 2008, 01:49:21 PM
Quote from: OilBarren on March 21, 2008, 11:12:19 AM
"...What's needed is to devise an experiment that clearly demonstrates a power gain. That's what's missing."[/b] PB
...ALSO THE DECREASE IN PRIME MOVER INPUT FROM 619 W TO 520 W HAS NO EFFECT ALSO?
THIS REPRESENTS ALMOST A 100 W POWER GAIN.
That is NOT a power gain, Thane. Your experimental setup was initially converting its ENTIRE input power (619W) to HEAT. When you changed the configuration, it was then converting only 520W to heat. So what happened was that you're now producing nearly 100W less heat. This is NOT any kind of a power gain. In both cases, you were converting 100% of the power into heat. In the first case, 619W of electrical input made 619W of heat; in the second case, 520W of electrical input made 520W of heat.
FINE HAVE IT YOUR WAY THEN - WE ARE ACCELERATING THE SYSTEM AND GENERATING ADDITIONAL POWER ACROSS A 1 K LOAD WITH 100 W LESS HEAT SIMPLY BY MAGNETICALLY COUPLING THE GENERATOR TO THE MOTOR.
ENGINEERING ENHANCEMENTS PROVIDE THE ROUGHLY SAME OUTPUT POWER ACROSS THE 1 K LOAD WITH 421 W LESS HEAT.
THAT'S A POWER GAIN (SAVINGS) OF 421 W + LOAD POWER DISSIPATION IN THE MECHANICALLY COUPLED SYSTEM OVER THE CONVENTIONAL GENERATING SYSTEM.
UPCOMING ENHANCEMENTS IN THE WORKS WILL PROVIDE ADDITIONAL POWER GAINS, ENERGY SAVINGS, HEAT LOSS REDUCTIONS ETC, ETC.
Thane
ramset
PB this is your chance!! 15 minutes in the spotlite !!   to rub elbows with the inventors!!  to help change the world!!  and you only have to drive 15 minutes!!  Chet
Thanks Grandma
markzpeiverson
Quote from: ramset on March 21, 2008, 03:32:35 PM
Or, just get HERSELF out of the computer chair and walk HER FLATBOTTOM ass next door?
:D :D ;)
PS: Thane, apologies to your neighbor if she isn't PB?
I'm sure she's got a very nice... naw, better not go there!   ;)
-Mark
We dance round in a ring,
And suppose...
But the Secret Sits in the middle,
And knows.    --R.Frost
