Tri-Force Magnets - Finally shown to be OU?
Started by couldbe, February 20, 2008, 08:45:25 AM
Omnibus
Quote from: Rusty_Springs on March 15, 2008, 12:59:33 AM
Hi All
The Trigate motor was a break through to me because I aways thought if you can get permanent magnets to work like an electromagnetic motor you would have a PMM, that is attract in move along and repel out to attract in again and this happens with the Trigate motor, I know a magnet moves from repel to attract and I know if you angle magnets right you can get them to go from attract to repel so first I came up with the Corner gate then the Trigate both systems attract in and repel out the difference with the Trigate is you can join them to make a loop then take a few out to give you something that a magnet will follow around then repel out to be attracted in again, comming into or moving out of a system was always the problem, you always had the attract back leaving or the repel away comming in the Trigate fixes that now theres no attract back leaving or repel away comming in so you can open a loop and not have the closed loop effect that all PMM systems have and you don't need shields to do this, the only question for me now is will this system keep spinning with out have to add energy.
Take Care All
Graham
No, such a thing doesn't happen. There is no "tri-gate" motor. If you disagree show it.
Rusty_Springs
Hi Omnibus
Yes I know its nothing I came up with it as I have said it doesn't spin well enough to do work and like everyone has seen it stops after a while but what it does show is you can make magnets spin using permanent magnets, the only reason I showed it in the Minato Wheel Group was to give people hope that something can be done btw I will be shocked if that you tube video came out before my first posting of this at the minato wheel group.
One thing Omnibus why do you put everything down with out even testing it I have not seen one creative idea come from you only bagging,
can you try and be a bit positive in the future its ok to tell someone there idea wont work and show them why but you don't have to downgrade them or bag them in doing so.
Take Care Omnibus
Graham
Omnibus
Quote from: Rusty_Springs on March 15, 2008, 01:09:07 AM
Hi Omnibus
Take Care Omnibus
Graham
You're wrong. Not only it doesn't spin well enough but it doesn't spin at all. For a magnetic motor to be pronounced as working it must make full turns on its own while self-starting. It should be perfectly clear that nothing like this has happened with what you think is your contraption and you need not push the issue further before you really make a working pmm. Even 9.999% closeness to the desired pmm is equal to nothing more than 0% success.
Yadaraf
Hi Omnibus
Take Care Omnibus
Graham
Rusty_Springs,
Hang in there Graham.  Focus on your experiments, which are very worthwhile.  Don't let yourself get distracted by the noise.
Cheers :)
Yada..
Rusty_Springs
Hi Yada
yes your 100% right.
Thanks mate and take care Yada
Graham
