Steven Mark´s associate Jack Durban comes forward with more info !
Started by zapnic, March 17, 2008, 04:28:58 AM
Grumpy
Quote from: BEP on August 30, 2009, 05:43:45 PM
@ALL
I agree with this.
Does anyone have any evidence that this SM is the real SM?
@Loner
I am still convinced the open TPU has a minimum of two tubes in it. There has been a lot of great work and effort to deduce the details of this one but I haven't seen any work that 'works'.
@Bruce
The way I see it the only time three frequencies is required is when you want to be rid of the magnets. Three will give you rotation direction control. Three is the only configuration that can consistently give you reverse group direction. aka. 'left hand rule', if you so choose.
BEP
The saturable reactor is identifiable in several TPU 's.
        -Frank Edwards
BEP
Quote from: Grumpy on August 30, 2009, 08:48:20 PM
Thanks but that is another point of contention for me. I have not seen a single bit of evidence or heard a provable argument that those are sat-cores. The only sat-cores that have a counter winding are split core types used for controlling AC power with a DC control voltage. Even if that was a split core the two halves are too close to function correctly.
Like I said in a past post: They appear to be miniature TPUs used to drive the larger coil sets.
I'll stop spewing here. I won't give and most others won't either  :)
Bruce_TPU
SM's Words from the .PDF:
"On to another point.
There is an inertia.
With the right combination of frequencies, you can actually create arevolving field with inertial!
That is what I havereferred to as , The inertia effect."
"The closer you get to the center frequency the more power you permit the collector to dissipate into a load.
the important difference here is that in the case of the radio, you tune into the frequency and amplify it for use.
In the case of my power unit, you create several frequencies within a space of the collector coil's circumference.
The frequencies are directly related to the circumference of the collector coil.
You can begin to collect the current and dissipate it with no need for amplification because the signal source also becomes the feed for the power source and has the natural tendency to run with gain.
It is important that you note that you can never tune too closely to the exact frequencies of power conversion because the power received by the collector will instantly destroy it.
We instead must deliberately tune off the frequencies of conversion in order to make the thing properly work.
Remember that it is like a furnace which feeds itself.
The hotter it gets the more fuel it gives itself to burn.
That is why the control units are so very important.
Without the control unit constantly monitoring the frequencies of operation and making the necessary changes to keep the whole thing off exact conversion frequency, then the unit would very quickly destroy it's self."
"The multiple frequencies traveling around the coils are of too high a frequency to provide for any motive effort.
They are only a means to achieve an end.
The multiple frequencies begin to feed themselves and the multiple kicks become a combined big kick.
I call it resonating.
That is why if you notice in the video tapes that it takes just a few seconds for the coil to begin to function at maximum effort.
You see, one little kick amounts to nothing.
However imagine if you had hundreds of thousands of little kicks combining into one big current kick ."
"It is an insignificant power supply except when the two transformers get slightly out of phase with each other, or when they are connected in reverse of one another.
Then you can measure all kinds of things going on.
You can generate all kinds of hash and multiple frequencies, and I do mean all kinds.
What I measured during this process was very interesting.
All these frequencies occasionally met at the same time with a much larger kick at the output."
"We seem to overlook so many things in our society.
They are right in our faces but we just look around them without interest at all.
When I began to study the effects of multiple frequencies combined together I found out that when you deliberately strive to create the worst case scenario of frequencies you start to get some very measurable kicks.
In themselves they are not much.
But if you make enough of them fast sendoff, you get a collectible power spike that is more then the power available to begin with."
"The key to the kick's strength and appearance was in how fast Tesla discharged the capacitors into the spark gap AND how fast Tesla STOPPED the flow of current AT the spark gap.
Tesla used all types of devices to stop this flow of current, magnets, a flame, counter-rotating engines.
His goals were to get the time in which the discharge is STOPPED to be much quicker.
As Tesla did this he found that the perpendicular radiations, the ones from the wires, caused electrical effects to appear in wires and other copper/metal materials near the STOPPED current/discharge.
These electrical effects could be made to create electrons on other wires and copper around his STOPPED current/discharge wire." (standing waves, when two signals from same source SMACK into each other, the current is STOPPED- Bruce)
"Listen, you need to make three coils or so one on topof the other.
But the important thing is to wrap thecontrol coils perpendicularly around the collectorcoils.
There need to be three of them all the wayaround.
Start them up one at a time each.
Firstfrequency then second harmonic component into thesecond, then the third.
When you eventually strike thecord look out.
you will know what has happened at thatpoint.
In the mean time you can measure a slightoutput even if you do not strike the exact cord."[/size][/font]
"I assumed that anyone working on technology this sophisticated would have a superior
knowledge of electronics and an understanding of PURE frequency output being a Necessity to
control the reactions going on inside the collector."  (reactions caused by the intermodulation of the three frequencies)
"By starting the oscillation you cause the current to flow in the collector which causes the magnification of the process within the collector which will ultimately produce the greater voltage and power in usable amounts during operation."
"Lamp cord is what I use to connect my speakers to my amplifier.
You should hear my new amplifier I have made."  (amplifier, mixer of signals)
"Any deviation from the original signal or addition to , Harmonic and intermodulation is not good for stereo enjoyment, you know...
Stereo? I have a three channel system I listen to.
Sometimes the three channels combine together to create the most magnificent sound you could imagine.
A whole new sound stage opens up and suddenly you are transformed to someplace else."
"The Kill switch....remember the kill switch, I do not want this to scare the crap out of any body and have them telling mamma, balming satan, god, or any body else."
When I began to study the effects of multiple frequencies combined together I found out that when you deliberately strive to create the worst case scenario of frequencies you start to get some very measurable kicks[/]. (Harmonics produced via intermodulation)
[/size][/font]
Intermodulation is ONLY the means to an end.  It produces the harmonics OF the fundamental, and hundreds of replicas of the fundamental also.  And at the THIRD ORDER intermodulaion, and incredible thing happens, and ALL EIGHT HARMONICS CONVERGE AT ONE TIME!!!!!
[/size][/font][/size][/font][/size][/font][/size][/font][/size][/font][/size][/font][/size][/font][/size][/font]
poynt99
BEP
Lindsay already put this question to bed a number of posts back. I assume this was from the real SM himself advising Lindsay of the fake:
QuoteThe person posting as Steven is not , Im sorry to say.
Perhaps this will give us some idea of the lengths people will go to to create chaos.
I think you're getting jerked around Stefan, don't believe it.
.99
giantkiller
Quote from: BEP on August 30, 2009, 09:46:01 PM
This my next process. The accident threw my schedule off.
Bias the whole ring but just shock a small part like Kunel. I have these builds ready for any freq and voltage.
--giantkiller.
