Thanks to ALL for your help!!
Gravity Magnetic Motor
Started by TheOne, March 29, 2008, 12:33:58 PM
AB Hammer
Omega_0
You have two inventors. The original and myself. I am in the proses of working with Ronnie on a new version of what he has done and combining with what I have done and I can do.  I was going to wait till after I finished my personal projects but after talking with Ronnie today it has been decided to build it with at the same time as one of my others this weekend.
With out a dream, there can be no vision.
Alan
CLaNZeR
Quote from: AB Hammer on June 25, 2008, 04:44:14 PM
Omega_0
@AB
So are you saying to hold back till the weekend, as you have new details?
If so then I will hold back and see what your new invention on the back of the original has to offer, rather than going for the original design.
Cheers
Sean.
http://www.overunity.org.uk
Omega_0
Well, AB, thats a good news...
I wish you all the best.
Please post your progress.
gwhy!
Quote from: CLaNZeR on June 25, 2008, 03:03:07 PM
Hi Gwhy!
Good graphics mate, well done.
Sorry to say the Tri-Gate lacks one thing and that is Torque, Okay you can added stronger magnets etc, but you then increase the size of wheel etc etc to match.
But good idea as I know exactly where you were coming from apart from you would have to rotate the middle magnet before the roller could do the down stroke.
Hi Sean,
    I think you may be correct about the torque but from some other test that I have done its not to difficult to increase just by increasing the dia and length of the roller mag. The middle mag will not have to rotate as there are two sets of trigates one pushing and one pulling , the drawing is not to scale and the end of the arm will not make a perfect eclipital motion more like a triangular motion. I have quickly tested this on a horizontal plane with one con rod and from a standing start it will be pushed around for about  260 degrees and stops slowly then just sits there it doesn't get pulled back the other way and when the trigates are setup correctly there is very little effort needed to tickle the middle mag back to the start. I am gonna make a crank so I can mount 2 con rods the the theory is it will fill in the missing degrees with a little bit extra  ;)
itsblockdog
Hi Omega!
Thank you for your focus. Please allow me a short period of time to reply. (a few hours...maybe a day). I feel your questionings deserve researched, detailed reasonings; For that: May I premeditate & respond with the utmost of my limitations?  Personal experience with the original devices - I stumbled; yet stood & fell....  R&D proceedure gets a bit verbose but, more.....
(In thought, and shall return........Ronnie
Quote from: Omega_0 on June 25, 2008, 04:02:48 PM
Hi Ronnie,
Most welcome. :)
I found your setup most interesting. It actually went full 360 degree (and more) with just a slight push, which means a LOT ! No body has done that before.
In the first part of the video, I can see the wheel turning and almost coming to a stop when the magnet below pulls it back again....
So my first question obviously is - as you know the setup better why don't you try to recreate it again ? Its only a wheel and a magnet afterall. For you it should not take more than an hour, for the rest, it may take many weeks to hit the right combination.
I see the in the first part, it worked without a wobble (elliptical path), so I based my model on that. If it must have a wobble, we just need to directly connect the rod to the magnet, skipping the restrictive slot.
I also see that in the first part, the bottom magnet is placed at an offset (not directly below the "piston"). While in the second part (crude setup), its directly below it. So we have at least two configurations. Only experiments can determine which one works best.....
So we may need to build both.
You are saying something about pole reversal, can you describe it more please?
All things are possible
