OU.com rules! Stefan is the man.
Started by konduct, March 29, 2008, 07:30:42 PM
Localjoe
Sorry old cartoon though you may have seen it.. Called Boris and Natasha
This boris guy states blatently when asked questions _ i know nothign !
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Bulbz
Quote from: Localjoe on March 30, 2008, 01:30:53 PM
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
Best regards.
Steve Ancell.
Prophmaji
Quote from: Feynman on March 29, 2008, 08:16:53 PM
Look this is absurd that we are fighting over such nonsense
QuoteMagnet motors can?t possibly work.
EDIT: Feynman does not agree!    (I had spoken too harshly)
"Suppose a flux path material is used as the stator pole of a permanent
magnet motor. A large permanent magnet is used to magnetize that short
length of flux path, as shown one the left in Figure 6-31, which illustrates a
concept for a magnetic motor. For convenience, imagine that the small
magnet on the right is not yet placed on the material flux path extension.
The flux path extension is energized by the south north pole of the large
permanent magnet on the left, and used as the stator in a rotary magnetic
motor.
As can be seen, the north pole of the rotor, shown in the figure, is attracted
to the resulting south pole of the stator. Power can be taken from the shaft
of the rotor while it is being attracted in to the extended north pole of the
stator flux extension. As it begins to pass the extension end, obviously if
nothing else is done it will develop back mmf "drag" by being attracted
back toward the north pole of the flux extension as it passes it.
However, suppose that ?just when the rotor south pole is passing dead
center of the stator north pole extension, one suddenly pulses a small flat
coil placed on the face of the extension, which serves the function of the
small permanent magnet shown on the right of the material flux path
extension. Further, suppose the magnetic field produced by the coil is
oriented as the field of the small permanent magnet, but is much weaker
than the magnetic field of the large permanent magnet on the left. A very
curious effect then occurs. This energized coil magnetizes the edge of the
flux path extension, to a small "skin depth" as shown, with a north
polarity. The magnetic flux is now bidirectional in that same material flux
path extension.
Further, this edge-switching action is performed so that it is this "partial
north polarity" of the now-altered extension that faces the rotor north pole
as it begins to pass the extension and enters what previously would have
been a back mmf section. Instead, now that former back mmf section is a
weakened forward mmf region, further accelerating the rotor. This action
breaks the Lorentz symmetry around the rotation path of the rotor,
resulting in a net nonzero (nonconservative) magnetic field. Hence the
entire rotor exhibits a net drive force around its loop. The rotor will
                                       376
Using sheer edges that are polarized and compacted can work as well, or better.
Ie,  grain oriented silicon steel plates, from a small transformer.
This will help inertia get the magnet past the 'stickum' point. The sticky point will be smaller and oriented, concentrated.
It's the time aspect as well, that is the issue. Combine that aspect with: getting past the start point of a drag race, or never stop completely, to conserve energy. Remember the losses at start up and final stop, the energy levels lost or consumed-they are huge. So orienting the edge with silicon steel  plates cuts the time and stop/start factors.
For example, placing the plates between the two magnets that form that S-N bridge, can cause a far faster 'snap' for field change to take place, thus aiding the rotation.
However, I have found myself, Omnibus to be a bit offensive, to say the least. High handed, rude and his contributions are minimal, with respect to fundamentals, IMHO..
I am not naturally a 'confrontational' individual..and to avoid getting into near fist-fight with Omnibus, I simply cannot contribute to a thread where he's been involved, in general. That his rudeness is tolerated- is intolerable. In his defense, he does have to put up with some pretty darned serious crap, but  he can just ignore it, and not respond.
I think he likely needs banning for a month, if he's told to can his behaviour -and refuses. then see if he comes back with less nastiness. The knife must cut both ways. To those who given him grief..and to he himself.
Cap-Z-ro
A lot can be learned from the method used by Lawrence Tseung to diffuse insults...he ignores the insults and simply puts forward his point respectfully.
End result = no dust-ups !
It takes to to make a fight.
Regards...
mental breakdown
Even Tesla lacked somewhat in the social graces and was seemingly devoid of any insight into his own personal demons.  Many of the greatest thinkers of all time are egocentric bullies such as Edison was to Tesla.  On a positive note Konduct has great big gonad's to crap on the floor in Stephan's house.  And Stephan has either thick skin or considers this type of conflict to be a necessary part of exploration toward a common goal (or has simply chosen to let everyone see who is crapping on his floor).  Nonetheless, if even one of the brilliant or quirky thinkers leaves this website due to being ridiculed, then this site is only a reflection of the same tactics the governments and big corporation partake in everyday to suppress free thinking.  On the other hand if Stephan arbitrarily banns members due to their careless and insensitive comments towards him or other members then he becomes the "emperor" and will have to play a "cat and mouse" game trying to keep those out of his website when he has a "Welcome Everyone" mat at his front door.
This "f**k you, retarded, idiot, Nazi", language is very entertaining, though how can it be productive?  Remember "There is no such thing as stupid questions... only stupid people".
Stephan keep up the great work.  I admire your work and dedication to the 'overunity" goal.  And to everyone that feels compelled to state, "I don't care what anyone thinks."  I question the purpose for such a statement...is it for the benefit of the readers?
I struggle with mechanics and physics and most of the other disciplines that are required to speak intelligently on the subjects scattered throughout this website.  I have been tempted to ask questions as I have some half baked ideas myself that may be against the almighty laws of the universe or quite simply would not work.  I cannot imagine sharing them in a forum that requires me to face the ridicule of a few individuals who chose to be adversarial rather then wishing them luck as they try and turn "coal into diamonds".
Good Luck to Everyone pursuing the dream.
N.B.
F**K you Omnibus and Konduct.  Grow up.  LOL  sorry couldn't resist.    ;D   Just kidding!  Lighten up guys....  Have fun.  Get a drink... Get laid...  or think of a way to utilize the heat in the friction produced from the condom during sex...
