I'm not one to get prematurely excited...but can someone explain this
Started by Cap-Z-ro, May 08, 2008, 06:34:41 PM
Dr.Greenthumb
8 hours later and 21.30 with no caps connected so it did charge some. I could move this down into the basement. Would the RF still penetrate the walls?
TheOne
I started from 4.99 to 5.01, but my batteries are full, not a good test, i need to discharge them.
Also when I try to read the batteries while they are connected the value are lower, I need to disconnect the batteries to get a good reading.
resonanceman
Quote from: Dr.Greenthumb on May 10, 2008, 09:19:27 AM
Dr G
That sounds like an  interesting  test ..... taking  it down into the basement should  block  some of the RF  .........if that is what we are picking  up .
gary
casman1969
Put it together in about 2 minutes...
Using two Litium Ion batteries in series, a small hobby rv motor and two 2200uf @ 16v caps.
Starting the test and watched the voltage increase from 7.20vdc to 7.25 in about ten minutes.
Completely clueless as to what's going on here. Used the diagram with the motor. Got to admit this is a little wierd. So who's going to be the first to explain this?
Carl
Dr.Greenthumb
Like resonanceman said it may be the artificial frequencies in the air from TV Radio etc.
I remember seeing a youtube video where a guy hooked up some rather large caps in series alone and they started to charge up from nothing.
