riddle me this HHO man...
Started by Nution, June 16, 2008, 07:12:59 AM
innovation_station
ok so after 2 hours of stright run it drew almost 16 amps it got hot production was verry good!!!!!   i am satistified
it is a finished unit with out a controller  :)  need more gas add another cell.... throw a relay and a fuse on it good to go ;D ;) 8)
ist
i will do a photo shoot l8r on
ps i used brushed finish both sides 304 stainless flat stock 22ga  :)  oh and brass contact bolts ;D
innovation_station
here is a dwg of the cell i was testing
ist
xddorox
Just a stupid question to be clear, the neutral plate is the one that doesn't bubble, right?
retrodynamic
Hey Body. Check this project::
The Gearturbine, power by barr, with retrodynamic dextrogiro vs levogiro effect, at non parasitic looses system, and over-unit engine. Details:
www.geocities.com/gearturbine
HHO King
Quote from: sigmaX on June 17, 2008, 10:30:03 AM
Hi peeps :)
I just build an HHO generator for my car. I am waiting to buy an amperimeter clamp, so I can be sure of current consumption.
Maybe someone of you can clarify some concepts to me:
There seems to be two "schools" about voltage and current (or maybe I got everything wrong).
1) Not more than 2 volts are usable for hydrolisis. BUT HIGH CURRENT is a must (being the most used configuration the ones that use +||||||- -||||||+).
2) (the one that uses pulsed current) is: LOW current but high voltage (like Meyer's tubes o ravzz pulsed current modulator).
My cell actually is composed of 16 ss plates (15cm x 5cm)  separated by 1mm aprox, in +-+-+-+-+-+-+- configuration. My tester was not a clamp one, and reached up to 10 amps. It gave an error. I took it off, and using my CB radio 12amps power supply, I also burned its fuse. Now I am wondering how many amps my "monster configuration" is eating ...
For the three or so seconds that it worked before burning out the fuse, the HHO production was VERY GOOD.
I used tap water, with no electrolytes added.
Now I am also planning to try distilled water, just to see if I can lower amperage.
If things keep being this out of scale, I will switch into pulsed high voltage, low current feed (with a power inverter, just to see what happens). Then I might try to build the ravzzz pulsed circuit, if things look promising (or keep the power inverter attached to the system).
Anyway; I am also building several measurement and safety sensors to be rigged into the HHO generator, inside my car:
A pressure sensor (that will monitor HHO build up and water level, inside the cell), a temp sensor (just to monitor if things get boiling), a voltage sensor, probably a current sensor (this one is not decided) and the whole contraption is controlled with a 70A automotive relay so my microcontroller can turn it on / off at any time. Just for the sake of it, I will throw in a transmitter, so I can monitor every parameter from the inside of the car without cabling anything.
I am waiting for some parts to arrive. The transmitting and receiving platform is already built.
So, if any of you got any idea or recommendation, I?ll be truly thankful...
Regards,
Enrique
You can find a nice pre-built HHO PWM at http://www.extremehho.com
