riddle me this HHO man...
Started by Nution, June 16, 2008, 07:12:59 AM
Nution
Ok, so I am fairly new to this. Not completely but, somewhat new none the less. I wanted someone with some knowledge to clarify some things for me.
Mainly, I am concerned with heat and amp draw. I am under the impression that the unit gets draws more amps as it gets hotter. So, with that said, what would be to much as far as amps and heat goes? Does it really matter? Not looking for over unity here also, just an "ICE" setup. So, again what is to much as far as heat and amps go.
What is the purpose of a neutral plate. I see some builds having many neutral plates and they do not produce much hydrogen. It will be something along the lines of +nnnnn-nnnnn+ or something along those lines, and they don't seem to do much at all. This leads me to believe the "n" plates are not really contributing to gas productions, so what would be the purpose, do they drop the voltage needed in the setup or what benefit would come from this?
That all I can think of for now. Just hoping I can get someone with some knowledge on these 2 questions to shine some light on this for me.
innovation_station
in my limited expercience with this
this is how im testing
let it go ..... see the result
i will tell u this  my unit indeed puts out a lot of gas i was going to make a 6pac of this but after last nights tests i dont think the 6pac is needed
im useing no soda just plain tap water
when the cell is at operating temp it is verry impressive cheep and easly made  :) ;D 8) i would think when it is at temp im pushing 1.5 -2 l /min
and btw the bubbler i use is awesome it has never flashed back beond it and last night we blew the lid off it 4 feet high but agin it never went beond it
6 plates closely spaced  and soak the juice to it  ;D
ist
Nution
Sounds good but I am looking for the answers to those specific questions. I didn't really see those addressed.
I am looking for the info on heat and amps, and why neutral plates are used.
donsimpson12
The neutral plates effectively cuts the voltage and current in half with each plate.
This is mainly for amp and heat control.
As far as heat goes, the container will be the main limitation of how hot you can get...
A PWM will help limit or control the amount of amp draw, but I'm in seach of the next step.  Getting more HHO with  less amps..
Good Luck..
Don
innovation_station
i have not tryed the netural plates yet how ever i will today ;D
i  know the result...   much more efficient cell with much less heat and amparge but from what i have seen  the cells should be split my opinion way too much work ......
i will try the 6 plate cell with 4 nutral plates +nnnn-  also i will try a dubble 6 plate cell  +nnnn--nnnn+
ist
