I tried to rebiuld a Don Smith Device
Started by GM, September 25, 2005, 04:19:40 PM
Google
I am not claiming anything at all. Just wondering if I add many secondaries and draw power out from them, will there be a load on the primary or not ?
Best
Liberty
Quote from: Google on March 13, 2014, 11:04:16 AM
Best
I'm not concerned about what you claim as some seem to get quite excited if they hear OU.  You will know when you really have something if you study it completely.
But to answer your question about the circuit, using the spark gap, you have effectively isolated a direct connection from the load to the input source.  However, you will only be able to extract or draw power out of the secondary AB at the rate provided by your cap/spark gap and driver circuit.  The load or current draw on the circuit is determined by how often you have to re-charge the caps after a spark dis-charge into the transformer and other circuit losses.
Hope this helps.
Liberty
Liberty
"Converting Magnetic Force Into Motion"
Liberty Permanent Magnet Motor
Google
Max energy draw cant be unlimited. ;D
Does magnetic resonant coupling between one primary and many secondaries lead to OU ? Don Smith said so, I am not confident though.
Best,
Google
@ Liberty,
In the Energy Amplification thread many people are shouting over the rooftops that they have working Free Energy OU
devices based on Teslas bifi coil and magnifying transmitter and lenzless trafo patents but they always talk in riddles and that thread is many years old.
Whats happening on this forum man.
Best,
Liberty
Quote from: Google on March 13, 2014, 11:20:33 AM
Best,
In my electronic experience, as soon as you draw energy from an oscillating series or tank circuit, you lower the intensity of the oscillation and change the frequency of the oscillation, due to the loss in the circuit.  There is no energy gain in resonance.  I think resonance can help with efficiency in the right application.  The resonance of a cap and coil are mainly used in radio circuits as a band pass or band frequency block.  I have not found any additional energy gain by using resonance.  Impedance matching is also very important in such circuits, as to the efficiency achieved.   But I have not ever seen in my experience, an OU increase in output due to any electronic circuit used.
Liberty
