gotoluc
Quote from: ashtweth_nihilisti on July 25, 2008, 05:16:14 AM
Here you go guys, a complete research paper with all your hard work on the water spark plug, Aaron, PL, ossie's and many more.This is like a digest so you wont have to goto through many forums posts, it can be periodically updated, just send me the stuff.
Goto the panaceauniversity: http://www.panaceauniversity.org/  Over unity research papers ->Ganga Shakti -Water Spark plug research (PDF)
Ash
Hi Ashtweth, thank you so much mate for taking the time to make this great pdf document.
May your hard work reward you and everyone. If we all would do this kind of selfless service we would be much more advanced then we are.
To everyone. I have added a link to the pdf file at the first page of this topic and here it is also: http://www.panaceauniversity.org/Water%20Spark%20Plug.pdf
The effort you put in will be what you receive.
Luc
ashtweth_nihilisti
Wow thanks for the kind words guys :) I must commend you guys tho, i just want the world to appreciate all the open source engineers hard work, thats why the non profit org is dedicated to yo guys exclusively  ;). We built this too in homage to you guys ill add it in as soon as i get the time.
Keep up the great work guys, the world needs you!,
Sincerely
Ash
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.geocities.com/glorybangla/cqtes.htm
plasmastudent77
Quote from: magneto_DC on July 25, 2008, 07:09:37 AM
Hello plasmastudent,
what exactly do you mean?
s1r had a connection from each distributer point to the 8 relay (and to ground) to open exactly only when firing.
But how did it fire? From the same point on dissi with a seperate wire to centre electrode of each spark plug?
So, he got a parallel circuit after each dissi point? (HV-coils in relays?)
Or in series dissi point to relay coils to spark plug centre?
(Or two dissis? Guess, NO.)
Where are the 10A, 50kV?
magneto_DC
Hi Magneto_DC
The way an ignition coil fires is by disconnecting its power. Because the power has been flowing through the coil , it establishes a strong magetic field in the ignition coil. When the points open, th epower flow to the primary coil is interupted, but the magnetic field resists this by creating a high voltage in the secondary coil to try and resetablish the power flow. At this point, the secondary voltage ( about 50,000 Volts ) is harnessed and sent to the spark plug by the distributor.
You could piggy back off the power flowing through the distributor such that when the power supply was interupted by the points opening ( an at this moment the spark plug is fired by the ignition coil ), the 8 relays attached to the 110V DC to the plugs would also open because the points opened ( no power flowing to all of the 8 relays ) and no 110 V DC would flow to the plug.
Sorry if its a bit convoluted ....going out for dinner  :-)
Cheers & beers
Steve
gotoluc
Hi everyone,
I would like to share video's of a replicator who had a great idea to use a smoke glass to show the spark size on video. He also has tested to see if gasoline will react differently in the next video. Also in the last video (just posted) he demonstrates a circuit design by Overunity user: capacitor70 and shows the power between gas and water.
Luc
http://www.youtube.com/watch?v=0eSlS3f7gn0
http://www.youtube.com/watch?v=ipWBcA6TC0g
http://www.youtube.com/watch?v=foytvHDYgEg
ashtweth_nihilisti
Back round on Aarons Gray tube added, new vids added any more let me know guys.
