gotoluc
Quote from: go-blue on August 12, 2008, 03:47:15 PM
Is there a transcript available for this broadcast?
Could be but I don't have it. Do some Google search.
Luc
gotoluc
Quote from: Grumpy on August 12, 2008, 03:21:54 PM
So, looking at the original S1R sketches:
It looks like he is just switching the half-wave 110 and the ignition spark through the relay contacts at the same time - same direction.
Where does that wierd coil fit in?
The weird coil is suppose to be a complete replacement for the relays.
Luc
goldenequity
Quote from: SPP-48 on August 12, 2008, 05:42:23 AM
@goldenequity
I ran the water droplet test as you suggested. The results were not promising, although still interesting. I was not able to use the spark plug as the droplet could not get close enough without jumping to the electrodes. I used tungsten electrodes with a wider gap. Using distilled water.
I have attached a small video taken with my still camera, so the quality is poor and was not able to show the true intensity of the spark. The video was edited to show only the spark action.
The first spark is with no water, then the droplet, and finally a water mist spray which seems to be the most effective in increasing the spark size and noise.
It is interesting to see how the spark is affecting the droplet, without exploding it. It is obviously an issue of scale. The droplet was too big. In the end, the motion created by the spark caused it to fall. This seems to confirm that misting, or fogging is best.
Cheers
Sam
Thanks Sam..... even 1 Drop is alot .... true!  Thanks for the attempt  :)
IndianaBoys
gotoluc,
Tried to post this to you at the energetic forum - water sparkplug thread for all to see, but it must take awhile for new accounts to be activated with priveledges. Maybe this will be of assistance?
RIDICULOUSLY SENSITIVE
ELECTRIC CHARGE DETECTOR
http://amasci.com/emotor/chargdet.html
This simple circuit can detect the invisible fields of voltage which surround all electrified objects. It acts as an electronic "electroscope."
Keep up the good work!
IndianaBoys
gotoluc
Quote from: IndianaBoys on August 13, 2008, 03:02:48 AM
gotoluc,
IndianaBoys
Thanks IndianaBoys for posting this simple test circuit. I will also post it at the Energetic Forum for you.
Luc
