Daniel Dingle Foundation
Started by ethospete, July 06, 2008, 01:39:22 PM
Barbicane
I have an observation and a question.
Dingel's vids show a solenoid bank under cover, with another unit for the four injector lines. he clearly states that the gas goes into the the solenoids, after the limitation and that the separated 02 goes to the intake manifold.
In the Dingel foundation image gallery, these units are not visible, the engine layout seems stock standard. It seems that both electrolyser and bubbler are different, but logical.
What is still being hidden after so many years, so much disinformation?
Barbicane
Barbicane
ethospete
Hi Barbicane,
Yes, you are correct in your observations. Daniel deliberately added other things that were not actually necessary to the process as 'red herrings' to try and throw the myriad of different people trying to 'steal his invention' over the years off the scent.   ;)
As you say, it does work in the logical way you would expect it too, just like other HHO Systems, but the key is the Dingle HHO reactor which has the fastest disassociation capabilities that I have seen to crack the covalent bonding in H2O to generate HHO gas and it produces roughly 1,000 litres an hour.
All the best,
Pete...
Barbicane
Hi ethospete,
Thankyou for your reply.
I find it hard to concede to an output of 1,000L per hour as it translates to something like 1 litre every three seconds. The psi generation would be enormous if compared to the visuals of what is shown (and I analyse frame by frame).
It seems to me that high plasma is involved very much akin to a "Joe Cell", in stage 3. This I can accept, paticularly if solenoids were utilised in conjunction with the plug operation. Thus an output of even 1 litre per minute would be all that is required, if that.
It is still sad to see that so much disinformation continues and all I can do is observe limited revelations.
Barbicane
Barbicane
malakabayo
In the Philippines alone it would cost the government around 73Billion in oil tax revenue
if his water motor goes to production.
If DD moves a muscle to make a production plant then his days on earth will be over.
Unless the whole world demands free energy then we are still to suffer for a long time.
source ph oil tax..
http://www.abs-cbnnews.com/storyPage.aspx?storyId=124444
ethospete
So we should all just sit back and do nothing while oil prices rise to $200 a barrel by the end of the year...???
