Fueless Friction Heater Manufacturer Found
Started by Cap-Z-ro, August 01, 2008, 02:59:08 PM
noonespecial
Quote from: resonanceman on October 13, 2008, 08:29:14 PM
UUUMMMMmmmmm
The  whole  reason for building this  kind of heater is  mechanical  losses .
The  concept is that the  mechnancal  losses  of  the moving oil will generate heat very efficiently .
It is  difficult  to get rid of mechanical  losses .......why not  use  them  for your benifit ?
gary
At the risk of sounding like a broken record.....:) How is it that mechanical losses of moving oil will generate heat very efficiently?
Electric heat, while pricey, is 99.99% efficient. Taking an electric source and adding a mechanical transfer mechanism will only make the efficiency go down, right?
Cap-Z-ro
"http://www.hi-lo.com/pages/products12-99.html"
Thanks for all your help gary...it appears those pulleys are designed for belt life and grip.
Regards...
resonanceman
Quote from: Cap-Z-ro on October 13, 2008, 09:25:48 PM
Regards...
I  didn't check the  prices ..... I am pretty sure that they  won't be cheap .
But they  are  built for industrial  use .
With one of those you can dial  in  any speed you want in a  fairly  wide range.
gary
resonanceman
Quote from: noonespecial on October 13, 2008, 08:42:46 PM
Electric  resistance heat is the benchmark  that  other  ways  if creating  heat  are measured by .
That  doesn't mean that there are not more efficient ways  of creating heat .
That is what  big energy wants you to think
Do you  believe everything you  read in a text book?
OU  will be found  in exploiting the  quirks  of processes .
This  heat  created by  turbulence  looks  like  a  really nice  quirk .
gary
Edit
In almost all cases  your text  books  will  tell you how to work around the quirks  rather than how to exploit them.
Cap-Z-ro
I'm pretty sure those pulleys are not able to give me the low speed torque and high rpm's at the same time gary.
Also, I think they are only rated for 1750 rpm's.
I hope I don't end up having to hook it up to my exercise bike.
Regards...
