BREAKING : **~Imhotep~**'s Free Energy Radiant Oscillator Lite
Started by Omega_0, August 03, 2008, 10:40:26 AM
waterhouse24
Quote from: robbie47 on August 08, 2008, 02:13:03 PM
Wha, ha, this thread  becomes one big comic strip  ;D
yeh it's a shame, overunity.com generally has some decent people (from my short time here..) I think i'll just become a reader of the forum from now on..
feeding trolls and all that
Vortex1
Quotef I plugged the same bulbs into the grid I would be drawing 36 watts... with this system i'm drawing 3 watts and charging batteries..
At that rate, sounds like your all ready to set up your own utility company with all those charged batteries How cheap will you sell the electricity? I'll be your first customer. Looks like the energy crisis is over, I can take a nap now.
robbie47
Quote from: waterhouse24 on August 08, 2008, 02:17:35 PM
Yes, please do.
Let me meanwhile explain why use of a small magnet changes the power consumption of a setting you show in your video with a completely misleading title.
A relay as used has a preferred switch position due to a mechanical spring. It costs a little bit of current and thus power to change this default switch position.
When a magnet is used, the tension of that spring is influenced. In the called 'sweet spot' the spring is just doing it job but almost no power is needed to bring it out of its default position.
This is why the power consumption is changing.
WilbyInebriated
Quote from: Vortex1 on August 08, 2008, 02:18:18 PM
please take a permanent nap fucktard...
i notice you didn't address the efficiency issue raised by waterhouse. just some typical 'asshat trying to be clever' response. not surprised you would be the first customer, it's people like you that run to someone else when they need/want something instead of doing it themselves.
jus' trying to save y'all some time...
waterhouse24
Quote from: robbie47 on August 08, 2008, 02:31:22 PM
Yes, please do.
Let me meanwhile explain why use of a small magnet changes the power consumption.
Dont' worry this will be my last post..
I understand what is happening with the relay..^^  That wasn't the point of the video.. It was to show the other people replicating, that it doesn't have to draw 1.5 amps as it was doing in the video prior to the magnet..  There is another replication here (http://www.youtube.com/watch?v=2PpMOrPSXkc) where he uses a 555 timer and gets the current draw down to 250ma with 4 energy saving bulbs.. The point is, this is a practical device that can be used around the home instead of just the usual bedini motor just turning and doing nothing useful... This can actually be used and uses less energy than if we plugged the same bulbs into the grid...
even though it is not OU and probably doesn't charge batteries.. the fact that it's only consuming 250ma at 12 volts is enough to say this is worth taking the time experimenting with..
I will leave it at that and continue experimenting to help bring a better future for my children.
