A "RADIANT ENERGY" DETECTOR
Started by Vortex1, August 06, 2008, 08:55:18 PM
Rosphere
Spider,
Sounds interesting and easy.  I would like to try it.  I just have a few questions:
Quote from: Spider on September 27, 2008, 12:36:57 PM
RE Detection:
Charge a 100V cap to 50V.
Cut two separate pieces of wire around 8 feet long that has good insulation!
Connect one wire to one terminal and the other wire to the other terminal - no circuit!
Curl the wires up into two rough cylinders, diameter unimportant!
Air coils?
Stranded wire ok?
QuotePlace near the coil,
Place the cap near the coil(s)?
Does the relative orientation of the coils make a difference; inline, side-by-side, other?
Quotenow pulse the coil
As in touch the unconnected ends of the coils together momentarily by hand?
Quotewhilst measuring the voltage on the cap and scoping the cap!
On the scope it looks like a very short burst of sustained oscillation!
Voltage on cap will steadyly rise! Cut wire down to get best pulse definition!
;D
Spider
A photo of your set-up would be appreciated.
Thanks man.  ;)
Spider
@Ro,
The cap and the 2 wires is just a measuring device. Its not generating RE.
You have to place it near your TPU, tetra or kickcoil build.
Like Spherics said, sticking 2 copper bars in the field already give a considerable voltage reading.
Even with what Marco posted you could measure RE near a device.
btw its not my idea, I got it from Spherics.
Spider.
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
turbo
Yes that is correct.
It is the copper supercharging effect.
These high voltage pulses eject the RE particles perpendicular out of the copper thet is being pulsed and this in turn charges up copper nearby.
In a vacuum tube the electrons are boiled off the heater in an exact similar way as water molecules escape from boiling water.
RE seems to brute force particles out of the metal that is pulsed.
However i would like to say that the voltages Spider mentioned are way too low to generate the effect.
In any case the pulses have to be higher then the ambient potential, the voltage all things on the surface are charged to.
As a guideline you can look at the QUAD ESL electrostatic loudspeaker.
It has build in two step up transformers and voltage multipliers , step up the low voltage to voltages well above 5000 Volts and higher.
Combine that with a delay line and you have found youreself a kicking setup.
In the ESL63 the standard delay is 24microseconds which responds to an runtime diffrence in air of about 8mm.
Steven was wrapping his own iron "bailing wire" delay coils so in essence he used diffrent timings.
Marco.
turbo
turbo
