Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
resonanceman
Quote from: wizardofmars on October 10, 2008, 05:46:00 PM
As for not caring where it came from - by your criteria, there are millions of random documents out there and you'll never get through them all. Figuring out if they came from a credible source (or some anonymous writer who was then 'reinterpreted' by a second anonymous writer) is important.
Wizard
Who is it important to ?
gary
Drannom
Hello
in fact a agree for sure that Brown's Gas seems a perfect way to melt easily two metals, a furnace might not be required anymore ! yeah
like steel-gold or steel-platinum, the steel and the (gold or platinum) is the body as well as the compound, so it's a molecule with an atom ! remember the easy way : the compound is the body !
i imagine to use Brown's Gas and then let the 2 metals crystallized while cooling slowly and putting a lot of volts at low current, and, hit them with physical shocks to turn the compound in the right direction while crystallizing, in electrinium there is an analogy of that with magnets
Z-Monkey has said
QuoteDrannom has said that the Alum Crystals that he grows convert the super light into visible light.
in fact alum pyramid convert super light in ASTRAL lights, not visible, those astral lights look like 3d shape geometric forms around the crystal, and there is bleu and green astral light coming out like a smoke over it, and much more....
my point is that all crystals are reflecting super light in astral light, very few are converting super light in electricity
QuoteDrannom, try altering the shape of one of you alum crystals mentally. Grow a sphere instead of a pyramid.
to get half of a sphere a have to let dissolve a pyramid under a vortex propeller, it work, and that will not help us in electrinium at all, hahahaha
to get electrinium, i am better try the easy way than the mental way, try and try again....
koen1 has said
QuoteMr. Summera seems to think that a compound molecule made of two
atoms which are relatively positive and negative valence-wise, has a
constant input and output of charge as in that the 'positive' atom puts out
a positive charge and the 'negative' outputs a negative charge, and that
this makes the compound molecule behave as a sort of electron pump,
absorbing electrons on one 'end' of the molecule and emitting them at the
other 'end'. We know this is not the case in reality.
thinking like this proove that you have not understand the electrinium at all, cause it's the compression of 2 atoms or molecules in a space shorter than normal that cause the electrinium to emit more super light than normal matter, normal matter is all in equilibrium, compression break the equilibrium
breaking this equilibrium produce electricity and fire in the universe
koen1 it is not the electrical charge of the atom, it's the difference in the weight of the atoms compressed in a shorter space.....
so the iron will not be the same with silver than with gold or platinum,
iron neg gold pos, or, iron pos and silver neg
i will not comment everything i read up to now, i hope to focus only on the electrinium
there is many easy way to find, for example if the compound is not harmonically tune the electrinium may produce heat instead of electricity
i think that egyptian used electrinium in water to produce torch with no smoke !
now i go to sleep with my dear wife and dream about how to find gold or platinum, and then ask to one of my friend to provide me some Brown's Gas
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
nievesoliveras
Hi!
@All
I know that you are a very special kind of people and very intelligent.  But my question is:
Besides showing that you are a knowledgeable person. Anyone has made any experiment with the fabrication of the electrinium?
Jesus
resonanceman
Quote from: nievesoliveras on October 11, 2008, 11:12:14 AM
Hi!
@All
Jesus
We are a special kind of  people?
Does that mean we get to compete in the Special Olympics?
;D ;D
Just kidding
I know  that   the  what you  said was said with respect .
To answer  your  question .
I  don't have the money right not  to  spend on   testing any of these ideas .
I would  hope that  by the time my money  situation  gets better we have a  good plan for a proof of concept  experment that won't take  a $500k machine   to  test .
So far my plan  is to test my power bead that I  posted  a while back.
As far as HHO   if  it can  be shown that it  cooks  the oxygen out of  quarts  it would  be a good way to  get  silicone  ready for  combining  with other stuff .........but I don't see a good way to   run  lots of  curent through  the  material  while heating it with  HHO
gary
sparks
   I believe that nature assembles macro atoms.  They are called plasma.  This is basically huge #'s of ions and electrons that have formed a structuring whereby the electrons circulate about the assembled proton mass.  I think Drannom assembles one when he makes his pyramid crystals.  I believe what we know as atoms are just plazma children.  And the Universe is still giving birth to plazma balls like the Sun from halo shaped plazma fields of immense proportions near the assumed center of the Universe.
   Anyway the creation of a substance that allows for a vectored flow of electrons not atomically entrapped would radiate high energy electromagnetic waves.  As soon as electrons are moving in a vectored fashion faster than light is able to pass through the same field different forms of energy are manifest.  Like the light around an atomic reactor vessel filled with heavy water.  Drannom's crystals are cool anyway you look at them.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
