Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
resonanceman
Quote from: z.monkey on October 07, 2008, 07:21:00 AM
Howdy Koen1,
Yeah, the key to Electrinium is Super Light theory.
Super Light theory is in the same area as the Soft Particle Physics theories that I was toying with earlier this year.  This same process excites the Crystal Power Cell and the Elemental Rods.  Also this theory is congruent with Henry Moray's Radiant Energy Receiver.  I just read a very exciting chapter in his book about the unlimited sea of energy we live in.  Here is a link to some information about Moray and his sea of energy.
http://www.hbci.com/~wenonah/history/moray.htm
The Super Light theory takes Morays theory a little farther by adding the dark central sun.  It is dark because its emissions are a lot higher that our optical sensors (eyes and instruments).  It is not just the reaction of the enormous amount of energy coming from our sun, but the perpendicular interaction between the energy coming from our sun and the invisible energy coming from the central sun which creates these effects in matter.  These two sources of energy interact with and add energy to matter.  The silver iron atoms join to become a molecule.  One side of the is producing negative charges with the added Super Light energy.  The other side is producing positive charges with the added Super Light Energy.  The effect which is produced makes the molecule a tiny pump effecting the space around it.  It becomes a molecular battery.  When these molecules become organized in series parallel structures then their effects can be amplified to create a battery.  A battery which is supplied energy from starlight.  Let me rephrase that, a strong, perpetual battery which is supplied energy from starlight.  I believe that the Crystal Power Cell and the Elemental Rods are doing an analogous job of converting starlight to electricity.  Both Tesla and Moray considered these phenomena to be caused by cosmic rays, and they were right, Super Light is a newer theory.
Edit:  I believe the first person to physically prove the existence of Super Light was Nicola Tesla.  His Plasma Shield technology from the WWII era used ultra high frequency energy (same as the central sun) which would dissolve physical matter.  He explained this was because of the energy radiated by the central sun.  This is in the Electrinium document.
Blessed Be...
One of the things Ilike about the  super light  concept is that it fits  with  all the other  stuff I have learned  about how life really works.
I don't  remember  where  but I read years ago  the black holes  were  natures recycling system ......physical stuff goes in  ......non physical energy flows  out .
This  sounds  like   super light to me .
Of course  the name  doesn't  really matter .
What ever  you call it there is  a  flow of  energy that is  beyond  physical senses .........and it is very powerful .
Personally  I find the least believable  part of the PDF is the part about the  Tesla Shield .
I  understand that in times of  war  sometimes  extreme  measures  are taken .
This  seems to me a bit to extreme.
A shield that   disintegrates any  physical matter that   passes through it .....from boarder to border .
Wouldn't this shield be kind of hard  on birds  and flying insects ?
It wouldn't be  very  useful  if  the enemy could  sneek  under it ........so what happens to the ground or water where it makes contact with the shield ?
One  potential  use of the technology  on a small scale  would be  for  waste  disposal .
On  the  surface  it sounds like the perfect solution to  our landfill problems...............but I suspect that  putting  the molecules  of our  waste into the air  is probably  no better than putting the waste into the earth in the long  run . .
sparks
    There may be sublight energy also.  Quantom physics predicts streams of neutrinos permeating well almost everything at high velocities.  Aether fabric? Magnetic particles? Gravity and anti-gravtiy just being a result of the relavent inertia of these particles.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
hypersoniq
@resonanceman
Hey, thanks for the links!
I did some reading and I found out that Rochelle Salt (Potassium Sodium Tartrate) Has strong piezoelectric properties... you can make that in your kitchen!
You might be right and I have now strayed off the electrinium path onto something else (piezo-electrinium ?  ;) ). But since I have neither the funds or equipment to start running Czochralski processes with the materials in the pdf, I think I will stick to the cheap and easy stuff until I at least have a working proof of concept...
The rochelle salt is the easy part, I worked with that decades ago for science class... the cBN will hopefully present an easy/cheap method of implementation and integration without getting into the whole nanotube issue...
Oh well, even if it's not electrinium, that book did provide some inspiration!
Good Luck to whoever pulls the first boule!
resonanceman
Quote from: hypersoniq on October 07, 2008, 09:24:08 PM
@resonanceman
Hypersonic
I agree that  it is good to work on what we can . .......
How strong is  the  rochelle salt crystals ?
Stong enough to  get  pinched  between  2 neos and take some vibration ?
gary
hypersoniq
Quote from: resonanceman
The 2 initial problems with Pure Rochelle Salt Crystals are
1.) poor tensile strength (it's the displacement of ions internally that makes it piezo-electric)
2.) tendency to absorb moisture
I need to investigate if there are ways around this using various dopants during the grow phase. I'm sure only experimentation will tell... (the cBN should change things, lattice wise)
(I know Sure Microphones used a rochelle salt crystal in one of their older microphone elements, and it was moisture-protected, but they didn't last long so they went with something else, most likely quartz)
