Do you wanna start a new project with me?
Started by Magnethos, September 28, 2008, 04:51:16 PM
Magnethos
I'm going to start researching about a new free energy experiment and I'm looking for people that want to collaborate in the project. The idea is develop and build the project, and share results and info together.
The project is about The Relaxation Time of a Conductor
The idea is that we can draw pure voltage waves (and 0 amperage, I don't mean a very low amperage that the multimeter cannot read. I mean NO amperage). In theory we could run a device using only pure voltage waves.
The experiment is very simple, because we only need to make a special alloy and a very simple circuit to pulse the energy throught the wire, because we would use PDC.
Results?
We could replicate a similar experiment like the Rod Generator
Info: http://peswiki.com/index.php/Directory:Elemental_Rod_Generator
Experiment Development
1. Theory and study of the project, as the determination of the main factors
2. Theory development about How to make the Project (how to build it)
3. Build the project
4. Test the results
gyulasun
Hi,
If you think of Bearden"s special wire alloy (Alu-iron) for instance then it all boils down to: for how much one can find a wire manufacturer willing to make that wire or any other wire alloy that may seem useful for a try.
Agree?
Gyula
Magnethos
@Gyula
Yes, I'm talking about Bearden's Alu-Iron alloy.
If the theory is true, there are infinite ways to develop technologies using this technique.
The problem is that making a homemade special alloy wire is difficult, so I have thought about to make Rods instead wires, because Rods are easiest to build than wires.
We could make a homemade special alloy Rods, to test the experiment and see if the results are true or not. If the results are true, then we could start the 2nd stage of the project: make the wire.
But the first stage is to make the rods, it's easy. There are some DIY manuals showing how we can build a inductive heater, to melt the iron and the aluminum.
The project could be like this:
The true rod generator project uses 2 rods, 1 with 73 elements and the second one with 74. We could make our own version, using the Alu-Iron alloy and extracting some volts from the thin air. In youtube you can find how to get some volts from thin air, easy to do also.
innovation_station
intresting
seems rodin's coil needs this wire or similar ......
anyone ever study mullers cores?
hummmmm
ist
amigo
Magnethos,
I wonder how exactly do you plan to "mix" up these elements into alloys (smelt, high pressure, carbon arc, induction heating...)?
I would think it is a pretty challenging task especially if you want to do that in the home environment. What about considerations of potential hazards like explosion, toxicity, burns, etc?
This place: http://www.mwswire.com/,  might be able to produce the Al/Fe (98:2) wire - I was thinking to contact them and ask. Maybe if there's more interest here they could do a custom "run" for us and it would be cheaper for all.
It would also be interesting to get enameled tinned copper wire as well, for some additional coil experiments...
