Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
baroutologos
Read the Perigo story. Something valuable comes out of it. that is FE claims.... are claims!
by the way, stop licking Tito's ass. i offered him 1.000 REAL USD in case he can teach me.
No asnwer. IMO he has nothing to offer since he possess nothing even though he may think he has.
How naive you should be to believe that he possess the secret and still he will decide to give it to you in case you are good boys and girls?
Wake UP
Magluvin
Hey Forest
I like what you said up there.  =]
That picture of a page in a book, what book is that? Or could you take a better shot of that?
Is it showing a resonant circuit building power at the bottom?
I want to try some resonant circuits at low freq. Like 60 to 1000 hz.
Thanks for that post.
Mags
forest
Quote from: Magluvin on January 23, 2010, 11:42:41 PM
Hey Forest
Mags
Magluvin,
I haven't that book.This shot was taken from Donald Smith video.
However consider this:
"Flutter is a self-feeding and potentially destructive vibration where aerodynamic forces on an object couple with a structure's natural mode of vibration to produce rapid periodic motion. Flutter can occur in any object within a strong fluid flow, under the conditions that a positive feedback occurs between the structure's natural vibration and the aerodynamic forces. That is, that the vibrational movement of the object increases an aerodynamic load which in turn drives the object to move further. If the energy during the period of aerodynamic excitation is larger than the natural damping of the system, the level of vibration will increase, resulting in self-exciting oscillation. The vibration levels can thus build up and are only limited when the aerodynamic or mechanical damping of the object match the energy input, this often results in large amplitudes and can lead to rapid failure. Because of this, structures exposed to aerodynamic forces - including wings, aerofoils, but also chimneys and bridges - are designed carefully within known parameters to avoid flutter. It is however not always a destructive force; recent progress has been made in small scale (table top) wind generators for underserved communities in developing countries, designed specifically to take advantage of this effect.[1][2]"
This is nothing secret as you see. If we could redirect energy from such disasters as Tahoma Bridge collapse we would have exactly free energy device.
http://en.wikipedia.org/wiki/Tacoma_Narrows_Bridge_%281940%29
Think clearly and you will be sure that it's simple and 100% possible. The only problem is in technical details of implementation.
power source->amplification->redirection of excess energy->energy capture
Tito L. Oracion
Quote from: sparks on January 23, 2010, 10:13:45 AM
   Echoes are cool.  Resonance.  Re sound
yes! every echo gives us a lot of magnification and replication of electron.  ;D
especially if we make use of an aluminum going to carbon the end result is times 3, wow we have a lot of energy.
from small tunnel to the bigger tunnel
don't forget the ice stone analogy ok.
Magluvin
Hey Tito
I have heard you say carbon a few times.  So it is just another facet that I have to look into. Not that I will find the answers for sure.
Thanks for the tid bits.  =]
Mags
