Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
0 Members and 17 Guests are viewing this topic.
forest
Quote from: delboy on May 02, 2010, 02:52:45 AM
...Now, there is a vast difference between these two, the electromagnetic and current energies.  That A which goes out in the form of rays, is, as I have indicated here, unrecoverable, hopelessly lost.  You can operate a little instrument by catching a billionth part of it but, except this, all goes out into space never to return.  This other energy, however, of the current in the globe, is stored and completely recoverable.  Theoretically, it does not take much effort to maintain the earth in electrical vibration.  I have, in fact, worked out a plant of 10,000 horse-power which would operate with no bigger loss than 1 percent of the whole power applied; that is, with the exception of the frictional energy that is consumed in the rotation of the engines and the heating of the conductors, I would not lose more than 1 percent.  In other words, if I have a 10,000 horsepower plant, it would take only 100 horsepower to keep the earth vibrating so long as there is no energy taken out at any other place
...Suppose that the earth were an elastic bag filled with water.  My transmitter is equivalent to a pump.  I put it on a point of the globe, and work my little piston so as to create a disturbance of that water.  If the piston moves slowly, so that the time is long enough for the disturbance to spread over the globe, then what will be the result of my working this pump? The result will be that the bag will expand and contract rhythmically with the motions of the piston, you see.  So that, at any point of that bag, there will be a rhythmical movement due to the pulsations of the pump.
That is only, however, when the period is long.  If I were to work this pump very rapidly, then I would create impulses, and the ripples would spread in circles over the surface of the globe.  The globe will no longer expand and contract in its entirety, but it will be subject to these outgoing, rippling waves.
Remember, now, that the water is incompressible, that the bag is perfectly elastic, that there are no hysteretic losses in the bag due to these expansions and contractions; and remember also, that there is a vacuum, in infinite space, so that the energy cannot be lost in waves of sound.  Then, if I put at a distant point another little pump, and tune it to the rhythmical pulses of the pump at the central plant, I will excite strong vibrations and will recover power from them, sufficient to operate a receiver.  But, if I have no pump there to receive these oscillations, if there is nowhere a place where this elastic energy is transferred into frictional energy (we always use in our devices frictional energy -- everything is lost through friction), then there is no loss, and if I have a plant of 1,000 horsepower and I operate it to full capacity, that plant does not take power, it runs idle, exactly as the plant at Niagara.  If I do not put any motors or any lamps on the circuit, the plant runs idle.  There is a 5,000 horsepower turbine going, but no power is supplied to the turbine except such power as is necessary to overcome the frictional losses.
Now the vast difference between the scheme of radio engineers and my scheme is this.  If you generate electromagnetic waves with a plant of 1,000 horsepower, you are using 1,000 horsepower right along -- whether there is any receiving being done or not.  You have to supply this 1,000 horsepower, exactly as you have to supply coal to keep your stove going, or else no heat goes out.  That is the vast difference.  In my case, I conserve the energy; in the other case, the energy is all lost.
I see now that Tesla words can be deciphered in two ways :
- standard : Earth is metallic ball like conductor, any current generated in power plant  is passed by conduction and fully recoverable , in opposite to EM radiation
- new look: Earth by magnetic field is connected to the "wheelwork of nature" and any power plant generating current passed to Earth is a disturbance of that field/connection, the receiver is then only transductor while energy source is Earth magnetic field and beyond
"Then, if I put at a distant point another little pump, and tune it to the rhythmical pulses of the pump at the central plant, I will excite strong vibrations and will recover power from them, sufficient to operate a receiver."
gyulasun
There is one sentence Tesla wrote that may shed some light if the receivers consume or does not consume from the plant he keeps the Earth in vibration with:
In other words, if I have a 10,000 horsepower plant, it would take only 100 horsepower to keep the earth vibrating so long as there is no energy taken out at any other place.
How did he mean it? if I take out energy from the vibration by my receivers, then I have to supply more at my transmitter site to make up for it?
My present understanding is that I have to...
Magluvin
[See Nikola Tesla: Colorado Springs Notes, page 324, Photograph III.]
FIG. 6. PHOTOGRAPHIC VIEW OF THE ESSENTIAL PARTS OF THE ELECTRICAL OSCILLATOR USED IN THE EXPERIMENTS DESCRIBED
I had arrived at the limit of rates obtainable in other ways when the happy idea presented itself to me to resort to the condenser.  I arranged such an instrument so as to be charged and discharged alternately in rapid succession through a coil with a few turns of stout wire, forming the primary of a transformer or induction-coil.  Each time the condenser was discharged the current would quiver in the primary wire and induce corresponding oscillations in the secondary.  Thus a transformer or induction-coil on new principles was evolved, which I have called "the electrical oscillator," partaking of those unique qualities which characterize the condenser, and enabling results to be attained impossible by other means.  Electrical effects of any desired character and of intensities undreamed of before are now easily producible by perfected apparatus of this kind, to which frequent reference has been made, and the essential parts of which are shown in Fig. 6. For certain purposes a strong inductive effect is required; for others the greatest possible suddenness; for others again, an exceptionally high rate of vibration or extreme pressure; while for certain other objects immense electrical movements are necessary.  The photographs in Figs. 7, 8, 9, and 10, of experiments performed with such an oscillator, may serve to illustrate some of these features and convey an idea of the magnitude of the effects actually produced.  The completeness of the titles of the figures referred to makes a further description of them unnecessary.
baroutologos
Too much speculation has been done about Tesla's saying etc. IMO from my half year involvement in Tesla technology i can safely states that Tesla was one of the most punctual scietists i know.
What he says it is literaly, what he means.
IMO plain LC resonance is a good tool for a number of purposes. I believe it has no OU potential in it. We must accept that profund truth and proceed our investigations.
forest
You don't understand. Something can be static like a mount or steady state like waterfall. Both can pass disturbance in the same manner, but only the second has hidden and usable potential.
If magnetic field is static then our  hope is in vain but if it's steady state then we have a possibility to extract energy from disturbance and that energy is not going from initial power source.
if Earth magnetic field is part of wheelwork of nature then we will can disturb it and exatract energy not from source power plant but from ambient source.
