Canceling Lenz's Law - Methods
Started by supermuble, November 19, 2008, 03:48:27 PM
petersone
Hi all
When ever i try a coil/magnet arrangement to cancel the Lenz effect, the coil gives less juice, when I cancel Lenz completely I get zero juice.Seems I can't get one with out the other!!!
peter
bjusticeforever
It was actually pretty simple....I just shorted out the back EMF (if that's the correct term.) I'm currently in the process of making a more efficient coil than the one in my video that Stefan posted a link to. Once that's accomplished, I'll make several and put them in series to really show the design's effectiveness, and the 'lessened' Lenz drag. I'm also trying to build them in a manner similar to an auto alternator to help lessen the 'cogging' of the rotor.
Sorry, but I don't have a meter to test the motor's amp pull (maybe Santa will bring me one) but I can tell you that the rotor has zero drag (other than the magnets) when spun by hand. Also, I've witnessed first-hand the effect of Lenz on a motor driving an alternator when it shuts down.....It comes to a immediate halt. This doesn't.
I'm not going to lie to you fellows.....a lot of this is Greek to me.....I have zero background in this stuff and everything I've learned has been self taught. I (sort of) understand the back EMF that causes the push-pull Lenz effect, and that's what spurred me to attempt this. I believe that the back EMF acts exactly like electricity and takes the path of least resistance....so I gave it that path. The real problem was 'balancing' the core to still induce current. I've learned a tremendous amount in the last year about this balance, and it's the key (in my humble opinion!)
I've followed Tesla's work with intense admiration and would love to create a more efficient method of generating power than what's out there for the sake of the environment and for energy costs, too. I'm particularly fond of Tesla's earth-core turbine (I don't remember what the devil it's called) that uses the earth's heat to drive a steam turbine.
Anyway, I'll keep you posted on any success that I have with this project.
Thanks for inviting me, Stefan.
bjustice
supermuble
Good responses,
I was also thinking that there must be a way to use reluctance, specifically the hysteresis of iron in a unique way that can reduce the effect of Lenz drag. Solid iron takes time to charge and discharge magnetically (hysteresis). I thought if you could make a piece of iron hold onto a magnetic field long enough, it could be used to oppose the force of Lenz's drag. I need to study this more because I don't know much about hysteresis.
"When a ferromagnetic material is magnetized in one direction, it will not relax back to zero magnetization when the imposed magnetizing field is removed. It must be driven back to zero by a field in the opposite direction." This could be very useful with the proper design in a motor, generator or transformer. Sourced from: http://hyperphysics.phy-astr.gsu.edu/Hbase/solids/hyst.html
Also it sounds like a piece of solid iron has a transistor effect, read: "The main implication of the domains is that there is already a high degree of magnetization in ferromagnetic materials within individual domains, but that in the absence of external magnetic fields those domains are randomly oriented. A modest applied magnetic field can cause a larger degree of alignment of the magnetic moments with the external field, giving a large multiplication of the applied field." Free electricity, amazing!!! ;D http://hyperphysics.phy-astr.gsu.edu/Hbase/solids/ferro.html#c4
When you try to make electricity without Lenz's law, you can still have Faraday's law of induction, and you can still make current. The catch is, it makes way less power in most configurations. The problem is, the books say you CAN NOT produce ANY CURRENT. They are directly lying! Read about induction and you will see many lies... Just for a reference, I have a Bifilar coil that I've tested extensively. Well if you hook up both windings against each other so they are producing ZERO net magnetic field when power is applied to them, and if you try to generate power on this bifilar coil by rotating a disc with magnets, you get amperage out of it, all this while having the bifilar coil wound against its self so it is NOT an electromagnetic anymore. Since the coil no longer has any external magnetic field that has any effect on the spinning rotor, there is zero Lenz drag. Without Lenz's law you still should make some electrical power in a simple test.
Kator01
Hello supermuble,
thank your for the hyperphysics-link - especially this part. Reading further on in the sub-hyperlink :
" Long Range Order In Ferromagnets " you can read :
" When an external magnetic field is applied, the domains already aligned in the direction of this field grow at the expense of their neighbor.If all the spins were aligned in a piece of iron, the field would be about 2.1 Tesla. A magnetic field of about 1 T can be produced in annealed iron with an external field of about 0.0002 T, a multiplication of the external field by a factor of 5000! "
I wonder how to do that. But it is close to what user sparks has tested : it is the returning of this enormeous mag. aligment-energy back to its initial state of domain-disorder.
@sparks : is the Lenz-Kickback involved in certain configurations if you use pulsed DC - eg. saw-tooth with  a slow ascending ramp and fast sudden cutoff which returns the best Kilovolt output in a flyback - what you mean ?
I found the following information on "magentos" - an ignition-system build by Bosch in the 30´s :
http://www.motoruf.de/mo/info/Arbeitsweise_der_Zuendanlage.php ( german website, just look for the pics.
and this here the english version of another Bosch-Related website :
http://histor.ws/dmag/desintro.htm
Have a look at 2.5 Efficiency at the left side navi-bar
Compare this to our new ignition-systems here :
http://bt-h.biz/terrytweaks.htm
I would like to ask you to help me in doing research on a lecture on magnetos by a person named "Steve Gillis" held in Sursee ( Switzerland) Subject of the conference 2007  : " Revolutionäre Energietechnologien "
( revolutionary energy-technologies )
it was stated that this technique holds a good chance for OU.
I found this statement at a german website :
http://www.secret.tv/category/Technologie_1269.html
Nor further access unless you pay for a video. But there must be a transscript somewhere.
Sorry, folks, about this german stuff but I have the feeling this is very important.
Regrads
Kator01
Kator01
Kator01
Hello Folks,
I found this guy. He is an American living in Germany :
http://www.borderlands.de/net_pdf/NET0907S13-18.pdf
His adress is in this pdf-document.
Also seem to be his website :
http://www.forgotten-genius.com/
May be he is a member here - I do not know.
Kator01
