Canceling Lenz's Law - Methods
Started by supermuble, November 19, 2008, 03:48:27 PM
supermuble
That last link you posted is great! There is a tremendous amount of research at this site: http://histor.ws/dmag/teil01.htm
There are lots of very clear photos and design information for generators. Of course, when reading, we always have to imagine alternative configurations.
The German website appeared to simply show a magneto and on the other website, a gravity wheel of some type. I didn't see any free electricity device?
I searched for the person you spoke about, who was in Switzerland. I could not find any information in English. I did find an article in .PDF format, but it was all in German.  I have no idea if this is the right link, but here is the only thing that looked like it might be the same guy. http://www.borderlands.de/net_pdf/NET0907S4-12.pdf
supermuble
Please correct me where I am wrong.  ???
This is my current understanding of creating free electricity:
Why you can create free conventional electricity with ordinary materials:
1. Moving magnetic fields create electrical current. Magnetic fields have less than no physical mass (no weight).
2. It does not consume energy to move something that has no physical mass.
3. Voltage creates a magnetic field. Amperage is not necessary since it takes very little energy to create a magnetic field.
4. Faraday's law of induction says that the strength of the magnetic field, the direction of the magnetic field and the rate of change determines the amount of current induced in a coil of a wire.
5. If you position any moving magnet paralell to a coil of wire, then the rate of change can be increased for free since there is no Lenz's law. For example, increasing the frequency of a primary winding has no cost associated with it, if the secondary coil cannot induce Lenz's drag on the first coil. (See Thane Heinz transformer). In this example, frequency increases will increase the power output for free.
6. If you have a generator that has no magnetic drag (Lenz's law), the speed of the rotor can be increased with very little input energy. For example, if you double the speed of the spinning rotor, you may consume 10% more power. However, If you double the speed of the moving magnetic rotor, you will have double the voltage and double the output power. That is a 100% increase in output power with only a small 10% increase in input power.
7. Without Lenz's law, a spinning magnetic rotor in a generator has no drag whatsoever, except those associated with air turbulence and mechanical losses in the bearings.
8. Without Lenz's law, it is true, that you often produce much less electrical current in a given coil of wire. However, since the "rate of change" or frequency of the system can be increased for free, and since the rate of change increases current, then it stands to reason that machine speeds can be increased to make up the difference.
9. An inductor at high frequency usually flows less current. High frequency induction creates more electricity in a secondary coil. If you remove Lenz's law, there is an inverse relationship between primary input power and secondary output power. In other words, as machine speeds, or frequencies increase, so does efficiency.
10. According to Faraday's laws of induction, you can create more electricity in a given coil of wire than is required to create a magnetic field that created it - so long as their is no Lenz's law. The only requirement is that the rate of change, either RPMS or frequency, must be increased to the point where induced current exceeds the input energy.
With the help of some experts in this field, we can create a name for these guidelines. Perhaps we can call this overall principle the FLUX SPEED LAW. "In a given system that does not exhibit Lenz's law, the magnetic flux speed can be increased until secondary output current equals or exceeds that of the primary."
sparks
 @Supermumble
    If the change in the core of the output coil comes in the form of a magnetic wave then we are getting Lenz law to work but who cares it doesn't effect the initiator of the wave this puts Lenz on our side of the fence.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
elektromann
this autor is member here, last year he was very busy
but unfortunatly, must folk coudnt follow his ideas.
I ave often phoned via skype with him.
possibly he will return if he follow still as reader all
the time. He is American , and stay longer in Germany
afte his US military time wasfinished.
EM
SkyWatcher123
Hi folks, just wanted to mention Ive never read Garry stanley mention he didnt obtain results with the 6 magnet/stator layout and ive looked through all posts i could find and ive built the same motor which is by far the best running motor ive built to date and have built many. Where is Garry Stanley anyway, what happened to him.
