TALE OF THE IMPLODING TV
Started by HEYDUDE, November 19, 2008, 09:18:04 PM
giantkiller
It was some kind of intermittent failure of the chip. So I repaired it and of course threw away the bad part! That is probably equivalent to burning down Alexander's Library.
I cleaned house and threw the baby out with the bath water. Real ARGH!
Prior to this I was gonna pump in 2kv. That is what made think of this thread
I got really dismayed and was ready to throw in the towel for good. But being a recovering 'Type A' personality i shut everything down and went to bed. As I stepped into the shower the next morning, Eureka! Harmonics causing heterodyning. Right in front of my face. Now in front of yours.
Glad somebody responded.
--giantkiller. Noise is our friend. 8)
Florian
Hi all,
I've been reading the threads for a while - (not yet all posts- they're quite a few) and I have not see anything yet regarding safety control.
If the TV story started everything we're looking here at very dangerous stuff - at least until the technology is well established.
It looks to me that the TPU , once started, would go into a kind of positive loop and - if not stopped somehow with some negative loop control - would continue until self distruction.
So my questions would be:
1) How to create the positive loop - for instance, if the first pulse would make particles in the collector ring move in one direction, how would you sense that movement and use the sensor output to shoot  again in the same direction.
2) As stated several times by SM, the "resonance" should not be allowed to be perfect. In a positive loop, the device would tend to go by itself to resonance so how would you sense that and how to use that sensor to control the "near resonance" state and eventually shut down the whole thing before harm is done.
Everybody posts about how make the TPU start generating power - how about controlling the events once they're started?
Any ideas?
Bruce_TPU
Hello All,
I believe I have hit on an important discovery.  Everyone wonders, if they are to start using tubes, what circuit?  What tubes?  Etc.  I think I have found a SIGNIFICANT clue!  I have spent all afternoon writing it up and have placed it into .pdf form for all.
I owe Marco a thank you, for I have built on some of his research, as quoted in the .pdf.
Enjoy!
Bruce
otto
Hello all,
thanks Bruce for the schematic. This schematic is very important!!!
I used a EZ 81 rectifier tube but its a wrong tube!! Im waiting for my 5U4 tube that I have ordered.
Now, electronics experts, show me what is sooooo special with the 5U4 tube. Im not so clever.
Otto
BEP
Quote from: otto on March 09, 2009, 02:20:01 AM
Otto
Not much is special about the 5U4. Is does use a filament for the cathode. This should allow superposition of the heater current upon the plate current.
Now the 5U4GB.... There are more special things. Add higher sustained current and voltage output.
500v-0-500v? = center tapped transformer secondary
300mV ? = typo - should be 300mA but same typo twice then he switches to 250mA?
Both are on the edge of the tube operating curve - intentionally overdriving the tube?
Feeding the 5U4GB with already rectified AC? Who knows? Silicon rectifiers can do some strange things.
Nice work Bruce. Keep in mind the power supply is just a power supply. The parts that make color possible are on the rest of the schematic.
