Cavitation. The key to overunity?
Started by Pirate88179, November 29, 2008, 10:50:09 AM
Pirate88179
Quote from: PaulLowrance on December 28, 2008, 01:13:54 PM
Of course not. It is a known fact that ambient thermal energy produces Johnson noise. It is very simple to measure Johnson noise. The energy comes from ambient thermal energy.
LOL, well that's a rather closed minded statement. I'd tend to believe that thermal noise is far far far far far far far more well proven to be a source of power than cavitation. I, along with millions of EE's can show you simple experiments to measure voltage fluctuations caused by ambient thermal energy. If you have some evidence that an iron core with wire windings causes matter to be converted into energy then by all means *please* post the details that include the gamma radiation readings.   :D
TheBuzz, he's prometheus, the same creator of the SMOT, correct?
PL
Paul:
You misunderstood me, or I was not clear.  When I said that if your device is NOT cavitation, then the theory that ALL free energy devices are cavitation is incorrect.  Make more sense now?  You see, I don't think they are and I think that your type device is but one of other examples that do not fit this theory.  That was the point I was trying to make.  I am sorry if I was not clear.
I don't think my earth battery is using cavitation either.
ramset
Its not my Theory
I have just noticed that the theory explains or helps to explain ,how when WE create an unstable /unnatural environment [cavitation] MOM [mother nature ]goes out of her way to reestablish order in that environment
This condition is opportunity knocking [a VERY VERY BIG window of opportunity]
Chet
Receiving energy does not fall into Cavitation or the theory as I understand it
Perhaps the BUZZ can clear this up
Thanks Grandma
PaulLowrance
Thanks for clarifying Bill. It is my hope that global "free energy" will become a part of every day life as soon as possible. Therefore, obviously I nor anyone would want a lot of time wasted. So, it seems to me that the cavitation theory contained in this thread is about converting mass to energy. If that's correct, then *******PLEASE******* legitimate researchers test this cavitation theory and get it out of the way so these good people can start working on something else, as it's very simple to test this.  Energy to mass conversion will produce gamma rays. See it's producing gamma rays. It would take just an infinitesimal amount of mass-to-energy conversion to show up on a meter. If that is not the theory in this thread, and it's based on some unproven theoretical aether theory, then IMO that is going far far beyond what's necessary because it's well known that we're surrounded with ambient thermal energy. One billion joules per m^3 to be exact, and twice that for water. That's conventional physics. And such ambient thermal energy is sustained by our Sun. Ambient thermal energy is always in all matter, day and night.
PL
PaulLowrance
All that's needed is a Geiger counter. There are well over a hundred for sale at ebay for less than $20.
Here's one for $15
http://cgi.ebay.com/Victoreen-CDV-715-1A-Radiation-Detector-Geiger-Counter_W0QQitemZ160306325904QQcmdZViewItemQQptZBI_Security_Fire_Protection?hash=item160306325904&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A15|39%3A1|240%3A1318
Here's another for $15
http://cgi.ebay.com/Victoreen-Instrument-Geiger-Counter-CDV-717-Model-1_W0QQitemZ190259748656QQcmdZViewItemQQptZBI_Security_Fire_Protection?hash=item190259748656&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A15|39%3A1|240%3A1318
My ebay search showed close to 170 of them for sale. It's probably a good idea to test the cavitation theory to see if matter is being converted to energy. If it doesn't, then at least you're more prepared for a nuclear attack.  ;D
PL
AbbaRue
The way I see it there are two types of alternate energy devices.
Those that use cavitation and those that don't.  ;D
Actually I see cavitation as a method of extracting energy from the Aether or ZPE or Vacuum which ever we call it.
Other alternate energy devices convert natural or radiant energy into a useful form. eg. solar cells.
I read somewhere that the amount of energy bombarding us from space
24/7 is enough to power 200,000 hundred watt bulbs for every man woman and child on the earth.
Collecting this source of energy would not come under cavitation, even thought the actual source of it may use cavitation.
But devices that actually convert matter into energy like fusion would use cavitation.
That is what we are here to prove.
I have fired up my argon discharge tubes again and am experimenting with using the output produced to run other things.
Filtering the output through a Microwave capacitor in series only allows the AC component to pass to the external circuit.
It is this AC component that is showing the OU characteristics.
This is an idea I have been applying to other devices on this forum too.
Filter out the DC and measure the AC. (Important experiment for all)
When I get around to it I plan on feeding the output to a MOT primary with neo's connected to it like IST showed us.
If 19 volts gives us a large increase in current what would 400 volts give us?
Also plan on finding a way to get the output from #1 to run #2,
if successful then I will use the out put from #2 to run #1.  ;D
If you don't hear from me for a long time it may be because I discovered a new source
of endless energy and am no longer here. ;D ;D
I have left instructions with my sweetheart to let the forum know if something happens to me.
We are  having an unusually warm spell around here the last few days,
I wounder if running my discharge tube has anything to do with it. ;D
Sorry guys I went to see "Yes Man" last night and am still in a comical mood today.
