Cavitation. The key to overunity?
Started by Pirate88179, November 29, 2008, 10:50:09 AM
PaulLowrance
Thanks for the info spinner. J.L.Naudin used a gamma counter (not sure of the model) to see if the MEG was producing gamma radiation. He found no gamma radiation.
I would agree with you that cavitation is not the key to *all* free energy devices. Thanes just recently said the same thing, so he also agrees with us. I would go as far as to say that to date there are no "free energy" machines based on cavitation.  :(
As far as I'm aware, my diode array is the first documented legit "free energy" device that includes every detail, including part #'s, that anyone could build using SMS7630 diodes, which the semiconductor industry refers to as Zero Bias Diodes. Please see my website and forum for details -->
http://greenselfreliantenergy.com
So yes, there is now an actual "free energy" machine. I have offered a legal business challenge to countless physicists and EE's that if my diode array is not producing a DC voltage across a load that I will buy their product. Contact me for details. No takers so far. Also, *conventional* physics, using the best small signal semiconductor mathematics, which is based on quantum physics, clearly shows that diodes *must* rectify ambient thermal noise. Even the acclaimed genious, Mike Engelhardt, creator of LTspice by Linear Technologies Inc. said that I am correct that the math shows diodes rectify Johnson noise. I have challenged countless scientists to show mathematical proof that diodes produce zero volts DC from Johnson noise. They cannot, because the math clearly shows that diodes must rectify ambient thermal noise.  Twelve months of extensive measurements with up to *three* layers of metal shielding far out in a wide range of rural areas have shown the diode array always produces a DC voltage. The diode array has been tested in oil baths and non oil baths. It's been tested with various types of low bias current voltage meters, including the recent electrometer using a chip that produces a few femto amps of bias current. So both the math and measurements show that diodes rectify ambient thermal noise.
As far as I'm aware, this is the first "free energy" machine that anyone could build that will work. It's not going to power anything you'll need, but it proves the concept. It will require a diode array chip to provide usable amounts of power. The SMS7630 diodes are large enough to handle with your hands. Just solder at least 100 hundred of them in-series, as compact as possible, get an electrometer, place in appropriate metal shielding, and you get DC voltage. See my forum for details.
PL
sparks
    I thought geiger counters were like little vacuum tubes filled with gas.  Then when the gas "absorbed" the wave energy it became ionized and it's resistance drops.  I always check for xrays by using an evacuated tube filled with mercury vapor.  Mercury vapor likes em waves so much it starts to glow.   Below is how a smoke detector works which uses ionizing frequency to create an electric current.
       Ionization detectors have an ionization chamber and a source of ionizing radiation. The source of ionizing radiation is a minute quantity of americium-241 (perhaps 1/5000th of a gram), which is a source of alpha particles (helium nuclei). The ionization chamber consists of two plates separated by about a centimeter. The battery applies a voltage to the plates, charging one plate positive and the other plate negative. Alpha particles constantly released by the americium knock electrons off of the atoms in the air, ionizing the oxygen and nitrogen atoms in the chamber. The positively-charged oxygen and nitrogen atoms are attracted to the negative plate and the electrons are attracted to the positive plate, generating a small, continuous electric current. When smoke enters the ionization chamber, the smoke particles attach to the ions and neutralize them, so they do not reach the plate. The drop in current between the plates triggers the alarm.
   What if instead of a battery we use a high voltage high frequency scource.  Then the ionized neuclei migrate towards the cathode and the electrons towards the anode.  But just when the going gets good we shut off the voltage.  The electrons keep going and charge up one plate and the neuclei the other.  Then this secondary charging of the capacitor is shorted out to a load of some sort and the cycle begins all over.  The big question here is do the electrons and ions pickup momentum because of the energy of the external field or do they go faster at their own expense in energy.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
PaulLowrance
Quote from: PaulLowranceThanes just recently said the same thing, so he also agrees with us.
Actually, here's the exact quote -->
I asked Thanes if he had tested his machines with a Geiger counter? He replied,
Quote from: CRANKYpantsFOR SOMEONE TO SAY IT IS "ONLY" THIS OR THAT IS JUST LIMITED THINKING LIKE ME SAYING THERE IS ONLY ONE WAY TO FLY.
MY THEORY IS:
THAT THERE ARE AN INFINITE NUMBER OF FREE ENERGY DEVICES OUT THERE OR WAYS TO MAKE THEM...
JUST LIKE THERE ARE AN INFINITE NUMBER OF WAYS TO FLY - OR CRASH OR MAKE A LIGHT BULB.
AND OBVIOUSLY SOME ARE BETTER (AND SAFER) THAN OTHERS AND INFINITELY MANY ARE YET TO BE DISCOVERED.
Grumpy
Quote from: PaulLowrance on December 30, 2008, 11:20:17 AM
Tesla has two patents on radiant energy receivers that capture naturally occurring radiant energy.  There was a nicely documented experiment confirming that the method works.  So, your diodes are not the first.
Eric Dollard has written and experimented a great deal with Tesla Transformers.  These are deemed to be OU, but I guess they do not fall under the "anyone can build" statement.
On the Geiger Counter, don't they respond to displacement current? - which is not an electron current.
        -Frank Edwards
PaulLowrance
Quote from: Grumpy on December 30, 2008, 12:13:43 PM
I don't know what you mean by radiant energy, but a solar cell captures solar energy, but obviously I'm referring to a different class of "free energy" machines. As you know, there are perhaps countless "free energy" machines, and I'd agree that it's possible a lot of them were legit, but the public does not have enough details right now to build such a "free energy" machine. Otherwise, I and others would build them right now and start powering my car and home. Are you kidding me,  :D , I'd love that!!!
I'm saying that my diode array is the first documented and detailed device that produces "free energy" across a load that includes all of the details to replicate and verify this very moment. One could say it's the "Pico Smoking Gun" because it only proofs the concept due to the small amount of power it produces. The next step would be the "Grande Smoking Gun."  A "free energy" device that could power a home.
BTW, last month I calculated that a home could live off of 1KW of *continuous* power. Of course you would need batteries to store the power when not being fully used.
PL
