RESONANCE EFFECTS FOR EVERYONE TO SHARE
Started by gotoluc, December 03, 2008, 01:26:15 AM
0 Members and 102 Guests are viewing this topic.
minde4000
Thank You gotoluc. I spent quite a bit of time trying to figure out all that. Currently I am working on my meyer wfc  (almost done tho) and have few coils wound here too. I can make it resonate with some 350V peaks while pumping 15-20ac sine and some 220khz+. Good SG is really cool toy I should say. Still not much can do on either of my projects without inductance meter. 1 more week
The link that I posted a while ago with crystal radio setup its just to take a look at the secondary pickup setup. Maybe it would be more efficient that a single cap you have right now. Whenever  I will have my tools I will try to tap into certain harmonics with secondary pickup using lcr frequency tuning.
Keep it up you all
minde4000
Here is a type of "imposion" coil according to author used in simple overunity device. Impressive design :)
http://people.tribe.net/c8d7e521-fb6b-480a-b20b-f6518aa2e45b/photos/2a92216c-e488-4ecb-895a-a6bdc24686e9
And very interesting pdf regarding LC resonant permanent magnet utilizing amplifier research tuning into permanent magnet resonant frequency.
http://www.panaceauniversity.org/Magnetic%20Resonant%20Amplifier.pdf
gotoluc
minde4000
Seems like there is a overunity/underunity Q limit for every circuit. It says if one can reach sufficient Q levels system would become overunity. I just disconnected a gator grip wire between cap and coil and hooked cap right on the coil and only due to test gator cable resistance elimination voltage resonant peak levels jumped by some 100V. Imagine having some ultraconductor wire for inductor coil and some high grade cap resonating. Q levels would go tenfold... Btw what is that company called ultraconductos? Are they actually selling those 300.000 times less resistance vs copper having plastic wires? Since as some others state that Q level is critical in over/under unity in such a devices it also very important that your secondary pickup coil circuit would be impedance matched with primary resonant and not overloaded above its current delivery "safe" limits to avoid interference with primary coil Q level to drop below unity. Just and some info I found at panacea..
gotoluc
Hi minde4000,
room temperature Ultraconductors would be nice to have but if you look at their site you can't buy some. Makes you wonder if this is real ;D
Good stuff though ;)
Luc
