RESONANCE EFFECTS FOR EVERYONE TO SHARE
Started by gotoluc, December 03, 2008, 01:26:15 AM
gotoluc
Quote from: AlienGrey on June 01, 2016, 06:37:55 PM
Hi just found this article, I'm not sure this statement is true as such, my confusion is the video the guy Luc is it ? talks about a narrow pulse gives him the best results, but then he has the same feed going into a CD4013 'D-type this device divides by two because it just triggers on the one edge so you would end up with a EW 50/50 waveform, if you want to correct this, sling the 4013 in the bin or rewire it for CLK reset mode with steering diodes or just use a device like the IR2111, this will give you a full bridge drive to your other two IR 2103 chips  or faster version, however you can  only get what is available locally with this logic the same applies to the power that is used to harvest it ;) . So not much chance of any real power here. but it could be useful for battery charging.
Hi AlienGrey, thanks for your post and emails.
You are much more knowledgeable in Electronics then I am. So I'm sure you're right on your suggestions.
In the past I have had many ideas to test but usually I fall short on how to build the circuit.
I'll keep you in mind for the next time.
Thanks for sharing
Luc
deslomeslager
Hi Luc,
Your first video already dropped 'dr Stiffler'. Have you seen his latest videos? The newest thread?
Would be nice if you could join that thread, some of your vidoe's here are heavily related. (imho).
gotoluc
Quote from: deslomeslager on June 04, 2018, 09:08:35 AM
Hi Luc,
Not sure what you mean by "Your first video already dropped 'dr Stiffler' "
Yes, I have seen his new video and topic. I had some similar experiments using a SG single wire but could never prove or disprove where the power is coming from. So maybe Dr. Stiffler will be successful at confirming.
At this time I'm busy wit Pierre's DZ generator.
Luc
