Knitel's InfinityPump
Started by wizkycho, February 16, 2009, 07:55:05 AM
spinner
Quote from: wizkycho on February 22, 2009, 06:05:50 AM
certain positive:
.most of water here is allready lifted so input path to cilinder is not 5m.it is now and can be drawn/made 1mm
maybe negative:
.new paradox point might have been created at a bottom ...but that allso is in mm.
counter maybe negative:
although I don't think so cause water is not solid. it will create many small wortex-es.that I think will add to mechanism of pump up action.
...but now water from bottom container allso has to climb millimeters to refill the addon tank
You don't even think it deserves experiment. Is there some simmilar experiment ?
Wiz
It seems to me you didn't got the "paradox" stuff (known for more than 100years ) correctly...
Please, check out all the basic hydrostatics stuff again....
"Ex nihilo nihil"
wizkycho
Quote from: tbird on February 22, 2009, 08:38:45 AM
hi wiz,
did you understand this from the link i gave above?
Why the pressure does not depend upon the shape of the vessel or the amount of fluid in the vessel rests upon three things:
  a. Pressure is force per unit area and this is not same as the total weight of the liquid in a vessel.
  b. A fluid can not support its self without a container. Thus the walls of the container exert a pressure on the fluid equal to the pressure of the fluid at that depth.
  c. The pressure at given level is transmitted equally throughout the fluid to be the same value at that level.
tom
well since I'm not ashamed standing infront of paradox and look so silly (anyone does)
so I'll give it/us another tought
would rubber type hose input pipe make any difference ?
Wiz
wizkycho
Quote from: spinner on February 22, 2009, 08:45:30 AM
If you don't want to explain it to me...what do You want?
Wiz
spinner
Quote from: wizkycho on February 22, 2009, 09:01:56 AM
Wiz
I want that all the newbies would understand at least the basics before they cry for the "fame".... OK!?
Wizkycho, learn a bit more... Before you claim the impossible.
As 1+1=2 in mathematics, there is an equivalent in physics knowledge..
How many times this basics stuff was explained? God knows....
Check out the facts.... Your textbooks, for a start...
Cheers!
"Ex nihilo nihil"
sushimoto
Quote from: spinner on February 22, 2009, 09:21:27 AM
Cheers!
... If you dont want to explain it to us.
What do you want?
Do you have any constructive or creative proposal as Wiz has?
Cheers.
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
