New inventor of a Watercar (Bike)
Started by rensseak, January 17, 2006, 02:19:10 AM
hartiberlin
Walter just tried it with hydroxy gas charged water in a balloon
and the balloon exploded when lighted !
Youn can look at this:
http://waterpoweredcar.com/nz/60minutes_NZ_TV3_10_17_05.wmv
and the youtube video needs a current macromedia flash player, look here:
http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash&promoid=BIOW
Walter Hofmann
Hi Kator,
the store process is nothing special right now I just used the electrolyte from my hydroxy cells but which havent powerd for 2 to 3 weeks standing on my bench with open outlet. I did realise that there is some hydroxy in it still after this long time sitting on the bench as I try to find out if a little waterpump whould pull a vacuum or if it whould pull water too. I connected the little pump to the bubbler and because I couldnt close 1 inlet to the bubbler I used the cell connected to the bubbler like I sayd no power to the cell and to my surprise the pump did pull bubbles out of the cell for about 3 to 5 minutes. this means to me there is some hydroxy still trapped in the electrolyte or water what can easely be removed and like the test with the ballon shows mixed with lots of air I guess about 200 to 500 times it can be used.
If it is true that the water in the bubbler what is just plain water where the hydroxy did bubble through, shows the same results, then a mist blown in a engine together with lots of air could theorethical power a engine, I will find out.
greetings
walt
Quote from: Kator01 on October 10, 2006, 07:38:26 PM
Hi Stephan,
can you give Info where Walter has described this store-process. I have problems with this google-videos. I never managed to open one video there.
Can you give some hint what version of realPlayer works for most formats. I have the version 10, but it permanently fails on .AVI, or has codex-errors etc.  I do want some reliable Player.
Thank you
Kator
hartiberlin
Hi All,
Walter is right !
It is an amazing idea to store the hydroxy gas just inside plain water !
This is must be the effect Steven Ryan with his waterbike
and also Byronnewenergy are using !
It is amazing !
Just boil normal tap or destilled water until all air
is gone out of the water.
Then let it cool down without shaking too much and
then do an electrolysis in it so the produced hydroxy will
also go "into solution" in the water itsself.
Then this hydroxy gas charged water can be used to power
IC engine motors !
As oxygen can be stored in aquariumwater by bubbling air through it,
also hydroxy gas can be stored in water !
I wonder, what will happen, if you freeze this water then to ice ?
Will the hydroxy gas then also still be stored in it ?
Maybe it can then detonate when initial detonation charges are placed
into the ice ?
Well, but maybe then in ice form the hydroxy gas
stays longer in the water and does not diffuse so fast out of it ?
So this would be a very interesting and cheap technology to store
energy in water and transport it, whereever you need it !
Many thanks to Walter for verifying these ideas !
Regards, Stefan.
hartiberlin
Here:
http://www.biosmeanslife.com/products.html
they stated it, that they use Hydrogen stored in Water:
"Bio Fuels for combustion applications and ultimately complete conversion
to Hydrogen Enriched Water for all energy requirements."
So it is clear, they just put hydrogen
into the water.
hartiberlin
I can now imagine,
how I am going to buy 3 liters of hydroxygas enriched
ice and put it into my graphite powder fuelcell and
use the molten ice to power my flat via the fuelcell.
It should be possible to just change the water from
the graphite rods inside the selfmade
fuelcell and have new power then again...!
