New inventor of a Watercar (Bike)
Started by rensseak, January 17, 2006, 02:19:10 AM
hartiberlin
Here is the website of Steve Ryan
http://www.biosmeanslife.com/
Too bad he did not yet publish the way he modifies
his water.
Maybe something simular as the new Linnard Griffin
watersplitting process ?
It seems he makes some special electrolysis, where the
water is just a bit splitted and the hydrogen still
is in the H2O solution stored somehow and
then maybe in a modified ignition engine burned.
Look here for a motor that also runs purely on water mist
just via a powerful sparkplug system:
http://waterpoweredcar.com/1978camero.html
I guess it is better to split the topics and post followups
about the pyramidelectrical power output in a seperate thread.
Regards, Stefan.
Big
Here are questions concerning the possibility of a scam with water fuel, and particularly the motorcycle video.
First, why is everyone using carburetors when no auto manufacturer uses them any more?  My automotive experience tells me that the only reason for some sort of fuel delivery system is for the sake of fuel delivery tailored to the type of fuel.  If one is not using a fuel that needs atomization, then they should directly inject the fuel into the combustion chamber.  Simple, and easier to control.
Second, why is everyone using an existing vehicle as a test bed.  I liked the idea of the dune buggy because there are less places to hide anything.  If one truly wants to eliminate any negative issues, one must be open.  The best idea is a frame, a seat, and the drive train.  While one may hide the proprietary details, he must clearly eliminate any possible alternative fuel source.  There cannot be a fuel tank.  There cannot be a separate creation of the fuel from somewhere else.  It must be done in the vehicle by only filling a clear tank with water.  The creation mechanism must be in the vehicle.
Third, there is no way that the water fuel will cause the emissions test to show carbon if none was used, unless the guy is adding a great deal of oil to the crankcase every day.  That can be confirmed by independent testing.
These scam artists are not nuts, they are simply very crafty individuals.  We need to be smarter.  They cannot be allowed to corrupt the real research being done by many others.  We need to require all to adhere to rigid standards of conduct and product presentation.
hartiberlin
Hi All,
now we know, how it works !
Walter Hofmann has just found out,
that one can store hydroxy gas inside water !
If you make an electrolysis and run the produced hydroxy gas
through water or just use the water, where you made the electrolysis,
then some hydroxy gas is just stored inside this water !
You can also see it in the Byronnewenergy.com
video,
http://video.google.com/videoplay?docid=-2385750951725931938&q=Byron+New+Energy
where they fill up a balloon with some precharged hydroxy gas containing water
and then pump up the ballon with their mouth with some air
and this puts air pressure onto the water, which releases some hydroxy
and then when they light the balloon,
the water burns on the surface for a few seconds !
The same Walter Hofmann just did and it also exploded his ballon !
This seems to be also the same process as Steve Ryan is using !
http://peswiki.com/index.php/Directory:BiosFuel
Although he seems to produce the hydroxy gas inside his water
probably in a different way in his special made tank...
Maybe he just uses special metals something like
Chemalloy dust powder in his tank...which also
can split water into pure hydrogen and oxygen
or something simular like Linnard Griffin?s redox process...
At least we now know, that hydroxy can be stored inside water
and that opens up a save way to store hydroxy fuel just inside
plain normal water !
Great new finding !
Many thanks to Walter to have verified it !
Regards, Stefan.
Kator01
Hi Stephan,
can you give Info where Walter has described this store-process. I have problems with this google-videos. I never managed to open one video there.
Can you give some hint what version of realPlayer works for most formats. I have the version 10, but it permanently fails on .AVI, or has codex-errors etc.  I do want some reliable Player.
Thank you
Kator
