Coral Castle 50 year old secret - NOW here REVELED
Started by hammuraby, February 26, 2009, 08:42:03 AM
giantkiller
If that vertical pipe along side of the generator runs down into the ground water basin Then you would have a place for one of the conductors to go.
--giantkiller.
BAHammer
Quote from: giantkiller on March 03, 2009, 03:24:48 PM
--giantkiller.
One thing about static heads, you calculate by the smaller one. this might be because water is not compressable.
hammuraby
mt English is just from school; i wish to understand what you say;
i think that "one of the conductors" means a :
une head pipe here: http://en.wikipedia.org/wiki/Dry_well
and the other head pipe is drowned in a surface (refilled in fired-brik!!) water pool
OR?: there is not a generator !! if you use this , the generator can have a 90% efficiency; and another 90% the motor = 81% for rise a load; and 81% for lower it !
in a full cycle , rise+lower, you lose a 35% (0.80x0.80 = 0.64)
this is JUST an idro-meccanical gravitation device....
we can put on some elettrical sistem, but is useless for rise-lower....
we will see
that a conic gear can save close then 99% of the energy in a lift work
hammuraby
@ GIANTKILLER
did you mean.....this ? you very smart, plus then smart grid !!
answere:
surprise : NO!!  there is not the necessity of a sink!!,
you can do that, and put the machinery,
in every point on a pipe that use a gravity distribution from a pool,
in every point, on a pump there is two force that work:
a poll action +, end push action+ = SAME force
1Kg/cm2 every ten meter of the delta <x> of levels, from the pool to discharge point
(thet is >++> if you discharge on bottom of sink, naturally)....
naturally, not on water pipe that came from a eletric pumps directly....
the capacity of accumulation-
storage and the gravitation distribution is the only necessity needed,
but i will explain after....
@ giantkiller
hammuraby
can you see this as a accumulator for a BLOK ? that use meteoric water in raining land as italy, india or...,
and: as a accumulator for a village in africa.??...store for sun energy
this sistem....can grow a LOT, someone there??
