Coral Castle 50 year old secret - NOW here REVELED
Started by hammuraby, February 26, 2009, 08:42:03 AM
forest
It's all interesting , but how can you explain that Ed moved ALL Coral Castle from another place ?
I doubt he prepared that new place previously,but nothing is impossible.
How an you explain heavy stones transport using ordinary truck ?
hammuraby
@justalabrat
yes loud was load, sorry
@forrest
at first, I hope that the technical speech remains divided between:
the MYTH,
and the possible method
that he used in order to astonish who was fascinated from this mystery….
and, i am sorry because I must smash a myth;
but is usefull to  try to explain HOW HIS old work can reborn ,
because there IS so' MUCH profit to understand that TODAY, for use it....
( usable in his memory, is better then remember a death great mith, did you agreed? )
usefull understand , as this can to give energy to a system that is not OVER-UNITY,
but certainly that is FREE ENERGY. you do not pay the (a little water masses) rain need to feed that!
I believe that HE had moved the enormous stones, probably using a bridge lifter;
and the vertical and horizontal movement was guaranteed from according to the second "sailed" two way hydraulic circuit (jacks);
the first one is "open" from the pool to the sink
remember that this device is
NEW
system and is JUST BORN, and I wish that you can see that have a big possibility to develop....I KNOW that, but is necessary a bases condivided
giantkiller
Sorry. I can't buy this.
www.leedskalnin.com
www.code144.com
And what I posted about the re-assessment of the items in the castle and how it looks across the universe.
Now lets drop these bombs...
The stone obilisks pertaining to water are for smelting purposes.  The little pools of water in some of the stone blocks are part of the sextant operation of the castle. Everything can be seen in the park from on the step of the North tower that faces south into the castle.
There is so much B.S about it all even by the castle guides. Not worth the 10 bucks going in if you're ignorant. But priceless otherwise. Glad I went.
The walls have vertical and horizonal grooves which enhance the acoustics and harmonics. The ball court of Chichen Itza has vertical grooves on its outer sides also.
Ed also had a bottle horn on a rotating arrow head shaped rock. This part is the horizontal navigation of a 2 part crane. He used the electrified charges of the generator to produce the lift. That is the vertical part of the 2 part crane.
On the iron door there is an image of 2 planets and a sun in the middle. That is not a sun. It is an atomic nucleas with a frequency controlled orbit of an electron. I.E. Keely. Change the frequency and you alter the diameter of the orbit which in turns lends it to matter dissassociation or association. Turn crystals into sand. The other planet on the door lies in the Goldilocks zone ~21 million light years away. And the great men of today think they found it first. Go figure...
If you haven't been to the Castle then the mystery still pervades. The neighbors never heard any machine sounds only singing of sorts. And the next day the rocks were up in place.
And when the castle was finished it was a sextant, a chronometer, a communicator. Crystaline structures ring true.
--giantkiller. Make the trip.
hammuraby
i am very proud to have had your attention…i follow all topichs....
but, i am sure that a NEW technique as i had explain, can give many possibility of development,
and be able to the acquaintance of many persons on this.....
especially, if this method  is the axiom for being able to have a system whit a great energy production capacity, using a rain, but more using a water gravity distribution.... in symbiosis whit electric energy...
and VERY easy to reply too.
because a system that leaves from:  SUPERFICIAL water rain management (refilled pool), and, that uses also drainage sink,
much profit can be done in the system "smart grid",
this also IS base for a system "into island" ,
with this ACCUMULATOR-pool in head of low voltage grid (territorial carryer) .
and with function of convergence of all the renewable energy
i can also call it a ITALIAN WATER DEVICE exponential lifter of masses
or SMART GRID NEEDed...emproving
, if this hurt your trusts, about Coral Castle
but will remain that Ed used a lot of tackles....
or,  do you think that egiptyans 400 ac,  was better then us ? he say....
then, i can show some photo that can help my ideas,
but CERTAINLY, is not a question on who between US , have the reason!
the question IS :
the device can work as I say? this is or not a good device? this is NEW ?
my wish is go on and develop this technique whit you,
and put exclusively the attention on the device, after...will change name to topic??
will be possible.....
kind regards mirco
